Headlight issue, High beams don't stay on? |
ewdysar |
Dec 9 2004, 05:35 PM
What happens here, stays here. Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 |
So my high beams don't stay on. They light up while I've got the lever pulled back but they go dark when I let go. Even the blue indicator works in sync with the lights themselves, lit while they're on and off when they're dark. The low beams work normally, they turn on on the next cycle of the switch and remain on until cycled again (see above). The green parking light indicator works as it should. I would like to get this straightened out before I install the H4's sitting in their boxes.
The car did sit for 13 years, in a garage until I moved to a house with no garage for the last year. I'm hoping this sounds familiar to someone here... TIA, Eric |
94teener |
Dec 9 2004, 06:45 PM
Member Group: Members Posts: 209 Joined: 6-February 04 From: Jacksonville, FL Member No.: 1,636 |
Yes, it's your dimmer relay, symbal "J" on the Curret Flow diagram, a little square alum. housed relay located on the back of the fuse panel. Change it.
Phil |
Lo-Fi Version | Time is now: 20th May 2024 - 02:16 PM |
