Headlight issue, High beams don't stay on? |
ewdysar |
Dec 9 2004, 05:35 PM
What happens here, stays here. Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 |
So my high beams don't stay on. They light up while I've got the lever pulled back but they go dark when I let go. Even the blue indicator works in sync with the lights themselves, lit while they're on and off when they're dark. The low beams work normally, they turn on on the next cycle of the switch and remain on until cycled again (see above). The green parking light indicator works as it should. I would like to get this straightened out before I install the H4's sitting in their boxes.
The car did sit for 13 years, in a garage until I moved to a house with no garage for the last year. I'm hoping this sounds familiar to someone here... TIA, Eric |
ewdysar |
Dec 10 2004, 01:34 PM
Let me see if I've got this right (probably over simplified):
So the Hi/Lo switch is just provides a bump to the relay to toggle between the two light circuits? That would keep most current under the dash and out of the column. If so, Pretty slick, those germans... |
Lo-Fi Version | Time is now: 20th May 2024 - 01:45 PM |
