Headlight issue, High beams don't stay on? |
ewdysar |
Dec 9 2004, 05:35 PM
What happens here, stays here. Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 |
So my high beams don't stay on. They light up while I've got the lever pulled back but they go dark when I let go. Even the blue indicator works in sync with the lights themselves, lit while they're on and off when they're dark. The low beams work normally, they turn on on the next cycle of the switch and remain on until cycled again (see above). The green parking light indicator works as it should. I would like to get this straightened out before I install the H4's sitting in their boxes.
The car did sit for 13 years, in a garage until I moved to a house with no garage for the last year. I'm hoping this sounds familiar to someone here... TIA, Eric |
ClayPerrine |
Jan 5 2005, 05:05 PM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
IIRC, you have to add a jumper wire to connect pin 30 to the red wth a white tracer that is connected to pin 56. The red with a white tracer feeds power to the light circuit. and the relay toggles that connection between the yellow wire on pin 56a, and the white wire on pin F. Pin S connects to a yellow with a red tracer wire, and that is connected to the turn signal switch. When it grounds pin S, the relay is momentarily energezed, toggling the state of the contacts to change the beam.
Bottom line. Put a jumper from pin 30 to pin 56. Pin 56 can be identified by the red with a white tracer wire. |
Lo-Fi Version | Time is now: 20th May 2024 - 03:10 PM |
