| stuartgto |
Aug 20 2013, 10:19 PM
Newbie ![]() Group: Members Posts: 15 Joined: 17-April 13 From: 94070 Member No.: 15,777 Region Association: None |
What is the correct way to position the clutch cable as it exits the body and meets the clutch pulley on a rear shifter? My current cable was routed in an "S" figure and above the heat exchangers because the cable is too long to go straight to the pulley. Hence the jacket is melted, but the cable still works. How much difference is there between a clutch cable for a side vs. a rear shifter? Routing it in an S curve, makes the cable rub the cable fitting before it meets the pulley.
Thanks |
| toolguy |
Aug 20 2013, 11:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,277 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California
like this. .
| Cap'n Krusty |
Aug 20 2013, 11:35 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
What is the correct way to position the clutch cable as it exits the body and meets the clutch pulley on a rear shifter? My current cable was routed in an "S" figure and above the heat exchangers because the cable is too long to go straight to the pulley. Hence the jacket is melted, but the cable still works. How much difference is there between a clutch cable for a side vs. a rear shifter? Routing it in an S curve, makes the cable rub the cable fitting before it meets the pulley. Thanks Side shifter and tail shifter clutch cables are all the same. The bowden cable needs to have a curve in it to work properly. The Cap'n |
| stuartgto |
Aug 21 2013, 07:08 AM
Lo-Fi Version | Time is now: 15th July 2026 - 03:46 AM |
