what do you think of this 914-6? [I bought it!], back to original Irish Green now |
siverson |
Aug 22 2013, 10:06 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
(UPDATED with comments below)
From the photos, this is what I see that is not correct. Anything I'm missing? Not correct / things to fix: - outside mirror - speaker boxes - after market front air dam - 80s radio - white valve covers - rust (?) spots on carpet - painted (?) headlight motors - 4-cyl center console - color change back to Irish Green - wheel center caps need to be anodized or something - incorrect jack - black plastic threshold plates and carpet cleat should be aluminum Not right but no reason to "correct" (IMO): - Euro lenses - Euro driving lights vs USA fog lights - 15x6 Fuchs (was originally steel) May or may not be correct: - horn button is not correct - center seat fabric should be smooth (Center cushion could be the Colgan aftermarket item, period correct) questions / not sure: - antenna may not be right... ? - repro rear trunk carpet (missing grommet). or might be orig. -Steve Attached image(s) |
Eric_Shea |
Aug 26 2013, 10:06 PM
PMB Performance Group: Admin Posts: 19,275 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE Anyone know why the factory did this on -6s? It doesn't make any sense to me. It's ugly and seems to serve no purpose. Only assumptions. I have a video of a 70's era 911 assembly line. The front end is installed as a completed unit as these go down the line. It comes toward the front of the car with the struts in a horizontal position and is tilted into position and bolted up in one smooth operation. It may be a flag to denote a six tub that would get the basic 911T front suspension (with the exception of the special 17mm 914 size t-bars with the 911 spline count). They could be aligned differently with the slightly different track and again, the black used as a marker to indicate a six. I kinda like it. It was applied with a sloppy brush and reeks of one of those quirky -6 things. I even emulated it on my build because I thought it was a neat, yet odd feature. (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-a-dfw.xx.fbcdn.net-1110-1377576409.1.jpg) |
Lo-Fi Version | Time is now: 20th May 2024 - 03:24 PM |
