what do you think of this 914-6? [I bought it!], back to original Irish Green now |
siverson |
Aug 22 2013, 10:06 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
(UPDATED with comments below)
From the photos, this is what I see that is not correct. Anything I'm missing? Not correct / things to fix: - outside mirror - speaker boxes - after market front air dam - 80s radio - white valve covers - rust (?) spots on carpet - painted (?) headlight motors - 4-cyl center console - color change back to Irish Green - wheel center caps need to be anodized or something - incorrect jack - black plastic threshold plates and carpet cleat should be aluminum Not right but no reason to "correct" (IMO): - Euro lenses - Euro driving lights vs USA fog lights - 15x6 Fuchs (was originally steel) May or may not be correct: - horn button is not correct - center seat fabric should be smooth (Center cushion could be the Colgan aftermarket item, period correct) questions / not sure: - antenna may not be right... ? - repro rear trunk carpet (missing grommet). or might be orig. -Steve Attached image(s) |
johnhora |
Nov 4 2013, 12:18 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Steve...
went and took a couple of shots of the air box off my 914-6 my snorkel was cut off (by a PO) long time ago...wish I could find one..anyone have one for sale?? you can see the holes for the cold start arrangement...they are plugged up right now with plastic hole plugs....it has metal studs, washers, and wing nuts for the snorkel and metal breather hose inlet... John Attached thumbnail(s) |
rgalla9146 |
Nov 4 2013, 05:52 PM
Advanced Member Group: Members Posts: 4,559 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Steve... went and took a couple of shots of the air box off my 914-6 my snorkel was cut off (by a PO) long time ago...wish I could find one..anyone have one for sale?? you can see the holes for the cold start arrangement...they are plugged up right now with plastic hole plugs....it has metal studs, washers, and wing nuts for the snorkel and metal breather hose inlet... John Jhoyas air filter is the one. The wing nuts,studs, plastic holders etc. are the same as the four sixes that I've owned. The cold start plumbing is missing. No need to collect those parts too soon. If you do find them don't dare connect them. Can you say "KABOOM" ? |
Lo-Fi Version | Time is now: 20th May 2024 - 01:36 PM |
