what do you think of this 914-6? [I bought it!], back to original Irish Green now |
siverson |
Aug 22 2013, 10:06 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
(UPDATED with comments below)
From the photos, this is what I see that is not correct. Anything I'm missing? Not correct / things to fix: - outside mirror - speaker boxes - after market front air dam - 80s radio - white valve covers - rust (?) spots on carpet - painted (?) headlight motors - 4-cyl center console - color change back to Irish Green - wheel center caps need to be anodized or something - incorrect jack - black plastic threshold plates and carpet cleat should be aluminum Not right but no reason to "correct" (IMO): - Euro lenses - Euro driving lights vs USA fog lights - 15x6 Fuchs (was originally steel) May or may not be correct: - horn button is not correct - center seat fabric should be smooth (Center cushion could be the Colgan aftermarket item, period correct) questions / not sure: - antenna may not be right... ? - repro rear trunk carpet (missing grommet). or might be orig. -Steve Attached image(s) |
Eric_Shea |
Nov 3 2013, 03:15 PM
PMB Performance Group: Admin Posts: 19,275 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Neither one is correct on the air cleaner, that said, neither is the air cleaner. The snorkel is correct but the cleaner housing is not.
Both should be "Plastic" wing nuts on black plastic studs with black plastic nuts to lock the studs in place. Speaking of plastic, the original -6 housing is plastic, low profile with the cold enrichment circuit squirters built in. You can possibly use an old MFI housing (same housing without the cumbersome enrichment circuit) but you may have to drill a few holes for your float vents. Black plug wires for sure. Carbs, yes but, how far do you want to go? They do look pretty bad though. I prefer new cloth covered fuel lines. Your call. |
Lo-Fi Version | Time is now: 10th May 2024 - 01:54 AM |
