what do you think of this 914-6? [I bought it!], back to original Irish Green now |
siverson |
Aug 22 2013, 10:06 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
(UPDATED with comments below)
From the photos, this is what I see that is not correct. Anything I'm missing? Not correct / things to fix: - outside mirror - speaker boxes - after market front air dam - 80s radio - white valve covers - rust (?) spots on carpet - painted (?) headlight motors - 4-cyl center console - color change back to Irish Green - wheel center caps need to be anodized or something - incorrect jack - black plastic threshold plates and carpet cleat should be aluminum Not right but no reason to "correct" (IMO): - Euro lenses - Euro driving lights vs USA fog lights - 15x6 Fuchs (was originally steel) May or may not be correct: - horn button is not correct - center seat fabric should be smooth (Center cushion could be the Colgan aftermarket item, period correct) questions / not sure: - antenna may not be right... ? - repro rear trunk carpet (missing grommet). or might be orig. -Steve Attached image(s) |
Eric_Shea |
Nov 4 2013, 11:18 AM
That's the MFI housing I mentioned. If you look at the top of your carbs you will see two float bowl vents sticking up between the air horns. If you look at that housing, it has no means to accommodate those vents. That said, I really like that housing because it is basically the same as the 914-6 unit but, without the cumbersome and somewhat dangerous cold start we mentioned in the previous posts. Solution = 1/2" Spade bit. Drill 4 holes. |
Lo-Fi Version | Time is now: 10th May 2024 - 01:48 PM |
