Bondo??????? |
Bondo??????? |
Gearren |
Dec 11 2004, 03:49 PM
Member Group: Members Posts: 91 Joined: 18-July 04 From: New Bern, NC Member No.: 2,362 |
I don't know the difference between the different types of bondo, so I was wondering what specific type of bondo I should use to fill in pin holes in some of the metal in the enginge compartment before painting over them?
IronHillRestorations |
Dec 11 2004, 03:51 PM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Allmetal. It's a metal filled epoxy filler that doesn't absorb moisture.
URY914 |
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,631 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I'll get flamed for this but I would say the cheapest stuff you can find.
Paul |
jwalters |
Dec 11 2004, 04:11 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
(IMG:style_emoticons/default/wink.gif) Go with an aviation grade filler---it is called featherlite--best thing is it is flexable, so it won't flake off.
This stuff weighs 1/3 of regular bondo--go to :www.aircraftspruce.com and look up in the composites section--they also have a great primer called---what the hell is that name??? I cannot remember, but go on to the site. That stuff, ohhh "superfill" this stuff will fill in imperfections for u--no glazing and it is compatible with all paints.. Good luck!!! (IMG:style_emoticons/default/beerchug.gif) |
Lou W |
Dec 11 2004, 04:13 PM
"Here Kitty Kitty" my ass...... Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain |
914helo |
Dec 11 2004, 04:14 PM
Member Group: Members Posts: 235 Joined: 29-September 04 From: Southern Utah Member No.: 2,859 Region Association: None |
I also like the US Chemical All-Metal. It's not the cheapest, but doesn't shrink and sands pretty easily too.
Gearren |
Dec 11 2004, 04:53 PM
What about bondo brand body filler? Also, do you prime the metal first, then put the bondo on, or do you just put on the bondo then prime it?
jwalters |
Dec 11 2004, 04:55 PM
QUOTE(Gearren @ Dec 11 2004, 02:53 PM) What about bondo brand body filler? Also, do you prime the metal first, then put the bondo on, or do you just put on the bondo then prime it? (IMG:style_emoticons/default/ohmy.gif) HELL NO-DO NOT PRIME FIRST!!! bare matel only--and "rough" at that--it needs roughage to really get a clamp on the steel!! |
Lo-Fi Version | Time is now: 17th May 2024 - 06:23 PM |
