Bench Testing the Alt, has anyone here done it? |
76-914 |
Aug 30 2013, 10:48 AM
I asked this question a couple of years ago and thought I would ask again. I have a few spare alt's and wondered how to bench test them. I know how to check them in the car but how are ours bench tested? I have gone into some flaps but they don't know how. Just said that ours won't work on their tester??
stugray |
Aug 30 2013, 11:40 AM
Short answer: You cant.
Long answer: If you setup a special bench you can. The alternator would need a voltage regulator plugged into the alternator harness (connector is the same as on the relay board) Then a 12V source (battery) would need to be connected to the D+ of the voltage regulator (red wire) with a 2-3W bulb in series. Ground the battery to the alternator chassis. Then fire away. Light should be ON before cranking the alternator. Once the alternator gets up to speed, the light should go out. Then apply the test load and monitor voltage. Stu |
LotusJoe |
Aug 30 2013, 12:28 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
Autozone tests for free.
914werke |
Aug 30 2013, 12:38 PM
"I got blisters on me fingers" Group: Members Posts: 10,066 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Autozone tests for free. (IMG:style_emoticons/default/headbang.gif) BTDT they cant test our alts. (IMG:style_emoticons/default/shades.gif) |
Bartlett 914 |
Aug 30 2013, 02:50 PM
I took mine to NAPA Auto. At first he said he couldn't then tried anyway. He made 3 runs. First two passed. The third failed. I am glad he kept trying. It was the voltage regulator connection that had him confused.
worn |
Aug 30 2013, 03:05 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
worn |
Aug 30 2013, 03:07 PM
I asked this question a couple of years ago and thought I would ask again. I have a few spare alt's and wondered how to bench test them. I know how to check them in the car but how are ours bench tested? I have gone into some flaps but they don't know how. Just said that ours won't work on their tester?? I have set up a mock test where I drive the alt from a drill and hook up leads. You can feel the load when it makes power. But then, I don't know how much I know from that. I found out it can make more than 12 volts, but not whether it does in a real load. |
Elliot Cannon |
Aug 30 2013, 03:19 PM
I know you live out in the "boonies" but you say there isn't an automotive electric shop that can't check out that alternator? If the alternator is making 14 volts or slightly less, then what's the problem. (Keeping in mind I know less about electricity than most people and consider it to be a technical kind of VOODOO). (IMG:style_emoticons/default/av-943.gif)
76-914 |
Aug 30 2013, 07:35 PM
I know you live out in the "boonies" but you say there isn't an automotive electric shop that can't check out that alternator? If the alternator is making 14 volts or slightly less, then what's the problem. (Keeping in mind I know less about electricity than most people and consider it to be a technical kind of VOODOO). (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/poke.gif) OK gramps, put on your glasses and go back read the first post. I said "extra alt's". I know you have lots of energy so come on down and swap these out for me while I start the car and check the voltage, one by one. (IMG:style_emoticons/default/biggrin.gif) |
Bartlett 914 |
Aug 31 2013, 06:47 AM
I took mine to NAPA Auto. At first he said he couldn't then tried anyway. He made 3 runs. First two passed. The third failed. I am glad he kept trying. It was the voltage regulator connection that had him confused. Bad diodes to the regulator? That is what I thought. I used a different alternator. |
Elliot Cannon |
Aug 31 2013, 10:55 AM
I know you live out in the "boonies" but you say there isn't an automotive electric shop that can't check out that alternator? If the alternator is making 14 volts or slightly less, then what's the problem. (Keeping in mind I know less about electricity than most people and consider it to be a technical kind of VOODOO). (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/poke.gif) OK gramps, put on your glasses and go back read the first post. I said "extra alt's". I know you have lots of energy so come on down and swap these out for me while I start the car and check the voltage, one by one. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/poke.gif) OK you Texas shit kicker, go back and read the first sentence of my post. (IMG:style_emoticons/default/av-943.gif) |
76-914 |
Aug 31 2013, 03:13 PM
Flattery will get you everywhere. (IMG:style_emoticons/default/biggrin.gif) I'll have to reread this tomorrow so I can figure out what you mean. Then again I just came in from an all nightter and can't even spell my own name right now. (IMG:style_emoticons/default/dry.gif)
timothy_nd28 |
Aug 31 2013, 04:15 PM
ILBT
Lo-Fi Version | Time is now: 17th May 2024 - 04:17 PM |
