New chasis - Broad overview to Swap Everything from Parts Car |
ky914 |
Sep 1 2013, 07:20 AM
Newbie Group: Members Posts: 28 Joined: 31-August 13 From: Lexington, KY Member No.: 16,328 Region Association: None |
New member but long time lurker. I have been given a 1973 914 with a 1.7 engine. Unfortunately, it is too far gone due to rust. I know the engine and trans were good when it was last driven over 5 years ago. It has been converted to dual Weber 40's. It hasn't been driven more than 50 miles in the last 20+ years.
For the last 3 years I have been looking for a chassis that is local, cheap, and rust free. I knew this was impossible. However, it looks like I just found what I was looking for. I am buying an abandoned project and getting the 74 chassis. The floor pans have already been replaced. Hell hole looks ok from the pics. Long's are said to be solid with some pitting. My fingers are crossed it is as good as it looks. Regardless, the price was right. I will be picking it up next Sunday and will post pics when they are available. I know a ground up restoration is huge, expensive and potentially cause for divorce. Can some of the experienced people on here give me a broad overview of the reasonable steps to transfer everything from my parts car to the new chassis? I assume I need to get the all of the body panels prepped and ready so I can paint before putting on all of the other parts. After it is painted and glass is reinstalled, I assume I will need to deal with getting the suspension and brakes in shape. After that, engine and transmission, etc... Let me know what you think the proper broad steps are that need to be done. I am assuming the car doesn't need additional work to repair rust damage. What are the big items I have to buy? Do you think I need a complete rubber kit? What things are necessary to buy? What things should be bought and why? Thanks, Michael |
boogie_man |
Sep 12 2013, 01:24 PM
Member Group: Members Posts: 308 Joined: 22-April 11 From: So Cal Member No.: 12,969 Region Association: Southern California |
Do not like that rear floor pan at all but the good thing is you have access to all the bad areas. Go restoration design's web site to map out what you need like the battery tray kit and rear truck floor pan some of the smaller rust issues can be patched. If you change the rear trunk floor pan, you can also repair that rear body panel to get it straight. You also get the jack mounts for the rockers where i've seen people completly replace then or section just the lower half. As these guys said, brace and secure that car to keep it square and straight. Take your time and it will reward you with a nice long lasting ride. Scott |
Lo-Fi Version | Time is now: 17th May 2024 - 03:14 PM |
