New chasis - Broad overview to Swap Everything from Parts Car |
ky914 |
Sep 1 2013, 07:20 AM
Newbie Group: Members Posts: 28 Joined: 31-August 13 From: Lexington, KY Member No.: 16,328 Region Association: None |
New member but long time lurker. I have been given a 1973 914 with a 1.7 engine. Unfortunately, it is too far gone due to rust. I know the engine and trans were good when it was last driven over 5 years ago. It has been converted to dual Weber 40's. It hasn't been driven more than 50 miles in the last 20+ years.
For the last 3 years I have been looking for a chassis that is local, cheap, and rust free. I knew this was impossible. However, it looks like I just found what I was looking for. I am buying an abandoned project and getting the 74 chassis. The floor pans have already been replaced. Hell hole looks ok from the pics. Long's are said to be solid with some pitting. My fingers are crossed it is as good as it looks. Regardless, the price was right. I will be picking it up next Sunday and will post pics when they are available. I know a ground up restoration is huge, expensive and potentially cause for divorce. Can some of the experienced people on here give me a broad overview of the reasonable steps to transfer everything from my parts car to the new chassis? I assume I need to get the all of the body panels prepped and ready so I can paint before putting on all of the other parts. After it is painted and glass is reinstalled, I assume I will need to deal with getting the suspension and brakes in shape. After that, engine and transmission, etc... Let me know what you think the proper broad steps are that need to be done. I am assuming the car doesn't need additional work to repair rust damage. What are the big items I have to buy? Do you think I need a complete rubber kit? What things are necessary to buy? What things should be bought and why? Thanks, Michael |
mepstein |
Jan 20 2018, 09:42 AM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
"If I start cutting out everything that looks a little like swiss cheese, I will likely be replacing a huge percentage of the metal. I see rust evidence a little at the top of the windshield, in the trays under the headlights, in the fresh air vents behind the doors, etc... etc... etc... There has to be a point where it is ok to grind out the rust with a wire wheel, hit with metal ready or ospho to keep more rust from coming back and move on without cutting out chunks of metal.
I think you only learn where that line is from experience. Seems like the answer I am getting from the experienced people on this forum is you should always cut out the rust and put in new metal. If that is the case, my tub may be too far gone already and I am better off to resume looking for a better candidate." Did you ever fix the rust issues? |
Lo-Fi Version | Time is now: 17th May 2024 - 04:57 PM |
