| Randal |
Nov 16 2013, 10:55 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
lots of great recommendations from very experienced racers here... springs store energy. stiff springs store more so the release (off-loading) is quicker. more skill is required to manage that faster release and to be ahead of the car as you go higher in spring rate. shocks dampen the spring energy. shock valving should be matched to spring rate. big changes in spring rate require changes in damper rate. im sure many will disagree with the correlation between spring rate and skill level. I am sure you are correct, that why I post here. I am trying to learn as much a possible. The 914 has re valved bilstein's which I now believe are matched to the springs. I think what I was experiencing was a high spring rate with a very low grip level from the med compound r45's which resulted in quick under-steer with little warning. With the increased grip level of the 35's the suspension is working as designed. In addition to the driver catching up to the car with the added seat time. Looking foward to next season! Driver catching up to the car. Story of my life. +1 (IMG:style_emoticons/default/smile.gif) |
| dlestep |
Nov 16 2013, 01:15 PM
I am smilin'... ![]() ![]() ![]() Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
Use charts as reference to get yourself in the neighborhood. Every 914 handles
differently under the same settings and every driver has their own style. Test, adjust, test, adjust, test and accept changes using your own ass. There are so many variables. But, you know that... What works great at Sebring, sucks at Lime Rock. If you think tires are important, try asking someone what pressures they're running. |
| Randal |
Nov 16 2013, 01:29 PM
| Woody |
Nov 16 2013, 02:39 PM
Sandbox Rabblerouser and head toilet scrubber ![]() ![]() ![]() ![]() Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
I don't run with any of you so this is what I run. 225/45/15 front, 275/35/15 rear. A6s. 19 front cold, 18 rear cold. 22 front hot, 21 rear hot. Car is 1850 pounds without driver.
| Randal |
Nov 16 2013, 02:58 PM
| Woody |
Nov 16 2013, 07:16 PM
I don't run with any of you so this is what I run. 225/45/15 front, 275/35/15 rear. A6s. 19 front cold, 18 rear cold. 22 front hot, 21 rear hot. Car is 1850 pounds without driver. Now you've gone and done it! (IMG:style_emoticons/default/unsure.gif) |
Lo-Fi Version | Time is now: 17th December 2025 - 12:52 AM |
