what's the proper undercoating for a 914-6? |
siverson |
Sep 19 2013, 03:20 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
I tried extending a thread on the originality forum, but not much luck there:
http://www.914world.com/bbs2/index.php?showtopic=152778 Anyone have photos of an original or 100% properly restored 914-6 showing the rear fender wells and bottom side of the rear trunk? It seems like black undercoating is never right as it was just applied by the dealers or ports (or something), and besides it's ugly. So, it seems like the good options for these areas appears to be: 1. metal -> primer -> body color paint 2. metal -> primer -> grey PVC undercoating 3. metal -> primer -> grey PVC undercoating -> body color paint Or ? -Steve |
Eric_Shea |
Sep 19 2013, 03:28 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I thought it was conclusive from that thread what was stock on a six.
#2 with some overspray for a #3 effect. (IMG:style_emoticons/default/confused24.gif) |
SirAndy |
Sep 19 2013, 03:49 PM
Resident German Group: Admin Posts: 41,612 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
siverson |
Sep 19 2013, 04:01 PM
So the bottom of the trunk floor should primarily be grey, with over spray just from painting some areas. Like this... ?
Body color: - upper engine compartment - lower engine compartment - front & rear fender wells - rockers Grey with overspray: - bottom of rear trunk (above transmission) - bottom of floor (i.e. the majority of the bottom of the car) - bottom of front trunk floor (around the a-arms) Is that right? I just don't think I've ever seen a photo of a 914 or 914-6 that was primarily grey on the bottom... ? -Steve |
siverson |
Sep 19 2013, 04:05 PM
And to confirm, this is never done:
> 1. metal -> primer -> body color paint There should be grey PVC everywhere, and then some areas are painted. Right? -Steve |
sixnotfour |
Sep 19 2013, 05:05 PM
914 Wizard Group: Members Posts: 10,418 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
pvc--
under rear trunk under front trunk wheel wells x4 engine compartment gets some= overspray color-- everywhere lower half of engine gets overspray every six I have owned has the black undercoat--thin floor bottom trunks bottom wheel wells x 4 engine bay lower half overspray Attached image(s) |
siverson |
Sep 20 2013, 02:43 PM
Great, thanks.
Is the "grey PVC" still available? Or what's the best modern replacement? -Steve |
siverson |
Sep 20 2013, 05:10 PM
Just saw this answer on the bird board:
http://forums.pelicanparts.com/porsche-911...-undercoat.html -Steve |
Dave_Darling |
Sep 20 2013, 08:09 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
rick 918-S |
Sep 20 2013, 08:48 PM
Hey nice rack! -Celette Group: Members Posts: 20,438 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I just posted over on the bird. 3M makes a gray rocker guard in aerosol. 08889 is the product #. It matches the small texture of the factory coating pretty well. I have some I will be using on Sandy's car as a touch up to the factory looking gray coating under the car and in the wheel wells.
rudedude |
Sep 21 2013, 08:01 AM
Senior Member Group: Members Posts: 508 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
Wurth has a special gun for their product that works really well if you are doing large areas
McMark |
Sep 21 2013, 09:46 AM
I have this seam sealer gun from Wurth and haven't found the correct combination of settings the replicate the pebble finish quite as perfectly as I would like to.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.tcpglobal.com-419-1379778374.1.jpg) |
sixnotfour |
Sep 21 2013, 09:55 AM
911 have the pebble finish ..914's PVC is pretty smooth with orange peel and sags here and there.
Garland |
Sep 21 2013, 11:22 PM
Restoration Fanatic Group: Members Posts: 1,328 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
911 have the pebble finish ..914's PVC is pretty smooth with orange peel and sags here and there. I agree, after cleaning off the black underside of my 72 - 4, this is what I found. Underside: Wheel housing: Floor pan: Under body: Paint close And the dove gray primer: Seam sealer |
OmaPossu |
Sep 22 2013, 06:54 AM
Member Group: Members Posts: 241 Joined: 4-October 09 From: Finland Member No.: 10,886 Region Association: Scandinavia |
I have asked Porsche Classic for help to have correct painting to my six. It took 3 months to have answer and it was: Please tell your 914:s VIN.
And now waiting again.. |
puffinator |
Sep 22 2013, 06:57 AM
Member Group: Members Posts: 193 Joined: 6-August 13 From: Annapolis, MD Member No.: 16,218 Region Association: MidAtlantic Region |
911 have the pebble finish ..914's PVC is pretty smooth with orange peel and sags here and there. I agree, after cleaning off the black underside of my 72 - 4, this is what I found. Underside: Wheel housing: Floor pan: Under body: Paint close And the dove gray primer: Seam sealer What did you use to clean off the black underside stuff? |
Garland |
Sep 22 2013, 07:58 AM
Patience and lots of time!
First I used a putty knife Second a razor blade Then lots of shop towels and body solvent. The wheel housings with all the seams, welds and edges where the undercoat guy tried so hard to cover was the biggest challenge. Now do I paint, or just toich up and seal with body wax? Almost hate to cover it up, but want to protect the bottom. Thinking paint bottom before color to gain this effect. The original body color is silver as seen in the wheel housings. Looking into color match for underbody primer color. |
rstover |
Sep 23 2013, 08:49 AM
Member Group: Members Posts: 136 Joined: 15-November 11 From: Kerrville, TX Member No.: 13,785 Region Association: Southwest Region |
Ferg |
Sep 23 2013, 11:39 AM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
John do you have a thread on that car? Looks fantastic! (IMG:style_emoticons/default/drooley.gif)
Garland |
Sep 23 2013, 08:52 PM
Soon I will start posting, I started this one 10 years ago, and stalled for about 8, but now back on track. |
Lo-Fi Version | Time is now: 3rd May 2024 - 03:23 PM |
