> Complete trans loss?, Shifts INTO gears...just doesn't DO anything.
CptTripps
post Sep 20 2013, 12:35 PM
Post #21
:: Punch and Pie ::
I'm stumped.
The car pulled into the garage, and now (after welding the flares on) it won't move. The car shifts into gears just fine. It just doesn't move. It sounds like the trans is engaging, but won't move. No sounds at all. (grinding, etc) The clutch hasn't slipped at all recently...no nasty smells or squealing. Just nothing.
I thought it may have been the U-joint bushings...so I swapped them out. Nothing.
I took the cup off and manually put it in gear. Nothing.
I spin one wheel, and the other doesn't move at all. I can't remember if it was like that before, but I'm thinking no.
Could it be as simple as a broken pin somewhere? I got Dr. Evil's notes, and started reading...but the sections that I looked through didn't help much.
The shitty part is that I'm a few weeks away from putting her to bed to start the Subaru conversion. I don't have the time/space/parts to work on that just yet...and don't want to spend time/$ working on something I was going to pull in a month.
So I'm kinda sunk until further notice.
Ideas?
CptTripps   Complete trans loss?   Sep 20 2013, 12:35 PM
76-914   If'n your going Suby I would park it. Did you ...   Sep 20 2013, 02:16 PM
Spoke   Calling the good doctor..... Good news is you...   Sep 20 2013, 02:17 PM
CptTripps   This is in the 901. I wasn't going to do the s...   Sep 20 2013, 02:46 PM
yeahmag   Did you idiot check that the CV's are still in...   Sep 20 2013, 03:00 PM
kg6dxn   Sounds like a broken CV... :(   Sep 20 2013, 03:02 PM
Chris H.   That's what I was thinking but wouldn't yo...   Sep 20 2013, 03:22 PM
kg6dxn   Start it, put it in gear and look under the car. A...   Sep 20 2013, 03:34 PM
BKLA   If the outer CV comes loose or apart, the shaft an...   Sep 20 2013, 03:40 PM
CptTripps   Hmmmm. Well...I have two options. 1: I have a cou...   Sep 20 2013, 03:53 PM
yeahmag   Don't get ahead of yourself! Jack the rear...   Sep 20 2013, 03:56 PM
rhodyguy   side shift?   Sep 20 2013, 04:32 PM
Valy   I bet it has to do with the clutch. What happens ...   Sep 20 2013, 05:18 PM
CptTripps   Definitely not the clutch. It's not even getti...   Sep 20 2013, 06:53 PM
McMark   Don't look at the axles. Grab them and move th...   Sep 20 2013, 07:29 PM
Dave_Darling   Can you spin a rear wheel without the half-shaft o...   Sep 20 2013, 08:00 PM
CptTripps   Great tips guys. I'll start there tomorrow and...   Sep 20 2013, 09:29 PM
Valy   The other wheel is not spinning since the clutch i...   Sep 21 2013, 09:43 AM
CptTripps   Anyone guess "Pinion Gear"? It wasn...   Sep 21 2013, 05:21 PM
kg6dxn   A 901 is OK for a V8 if driven properly. You must ...   Sep 21 2013, 05:50 PM
CptTripps   I was gentile. I don't think everyone else was...   Sep 21 2013, 06:01 PM
- Lo-Fi Version Time is now: 13th July 2025 - 08:41 PM
