| 914itis |
Sep 21 2013, 01:17 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
I am tryng to bench start my 6 with carbs. I have fuel but no sparks.
I check the points and they are opening and closing. All grounds are connected. Positive is applied the positive side of the coil. The only thing I am not sure how to chck is the cd box. As far as I can tell the c box is powered from the positive side of the coil. help! |
| SLITS |
Sep 21 2013, 03:43 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
3 pin
A = + or 15, coil hot primary terminal ( - or 1, coil ground primary terminal is connected to the engine ground). B = Power from ignition switch. C = Distributor breaker points. D = Ground ![]() |
| r_towle |
Sep 21 2013, 03:55 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
If you put a condenser inline, you can remove the CD box for testing purposes if you question it's functionality.
| 914itis |
Sep 21 2013, 04:11 PM
Here is what I did.
I hot wire the coil by grounding it and 12 Volts at the positive of the coil. I have fuel but no spark. I tested the points, they are opeming and closing. I check the cd box, pin a has 12 bolts, b is dead and c has ground. I applied 12 volts directly to b, still no spark. How do you test a cd box? |
| Eric_Shea |
Sep 21 2013, 06:05 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Plug it in. If you hear a high pitch whine, it's probably working. If you can't hear a high pitched whine, ask your son if he hears it. If not, probably not working.
| DEC |
Sep 21 2013, 06:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 632 Joined: 10-November 05 From: Rehburg Member No.: 5,104 Region Association: Germany
You can't test the CD box without any special test equipment
If you don't hear a whistle from the CD box the box is not connected correct or is defect. |
| 914itis |
Sep 21 2013, 10:13 PM
| larryM |
Sep 22 2013, 12:20 AM
emoze ![]() ![]() ![]() Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California
based on what you say above, you have the wiring all wrong
(& where is this no-spark condition evident? - at the end of the coil wire or at the end of the plug wire, or both? Study very carefully the diagram above from SLITS , get out your 911 repair manual that has the wiring diagrams in it, and follow those diagrams (you do have one, eh?) you should not be hooking up 12v directly to the coil (do not ever leave 12v hooked continuous on the coil when it is grounded - it WILL overheat and blow up) (then all that fuel you see will create some excitement) 'b' should not be dead if you have hooked 12v to it as if you pretend you had a ign switch there (- better yet - DO put in a switch so you can control the thing easily) 'c' should only be grounded if connected to the points lead and if the points are closed - prop them open & check it again - Make sure the CDI ground is attacjhed to engine ground is attached to the battery ground - you say above that 'c' is grounded - but later not ???? - if still grounded, or grounded when not connected, you either have the wire from 'c' to points shorted to ground somewhere or likely the CDI is shorted internally . OR - just pretend you don't have a CDI at all - pretend you have a simple old fashioned ignition like your old VW Bug has: 1. hook 12v to Coil (+) via a switch, 2. hook the Coil (-) to the Dist Points lead and hook in a condenser at that junction as advised above, being sure the condenser is also grounded 3. Make sure the engine ground is attached to the battery ground 4. Switch on the 12v to Coil, and trigger the solenoid to crank it (well - you don't really have to crank it to test for spark - all you have to do is momentarily open/close the points, or disconnect the points and very momentarily ground the lead from 'c' to simulate the points open/close event 5. if still no spark - you likely have a short in your distributor, such as mis-installed points, et al, - - or your coil has gotten cooked already from that incorrect wiring . |
| 914itis |
Sep 22 2013, 05:45 AM
Thanks, ground was not connected on Cdi box started right up
| jimkelly |
Sep 22 2013, 07:45 AM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
now that is a happy ending (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 20th December 2025 - 05:05 AM |
