> Oil leak, Valve guide??
Elliot Cannon
post Sep 24 2013, 03:12 PM
Group: Retired Members
Could this leak be coming from a crack in the head at the valve guide?
Elliot Cannon   Oil leak   Sep 24 2013, 03:12 PM
stugray   My first thought was that there is nothing up ther...   Sep 24 2013, 03:48 PM
SirAndy   AND - B|tch slap whoever put all that sillycone on...   Sep 24 2013, 04:05 PM
396   AND - B|tch slap whoever put all that sillycone on...   Sep 24 2013, 04:12 PM
Elliot Cannon   I ask for help and I get criticized. Sheesh. I f...   Sep 24 2013, 09:24 PM
SLITS   I ask for help and I get criticized. Sheesh. I ...   Sep 24 2013, 09:25 PM
Elliot Cannon   OK, I'm pretty sure the inside of the exhaust ...   Sep 25 2013, 02:19 PM
Dave_Darling   :( I'd agree; time to pull that head and have...   Sep 25 2013, 02:43 PM
r_towle   could be headwork, could be junk rings. Pull it, ...   Sep 25 2013, 03:03 PM
Elliot Cannon   could be headwork, could be junk rings. Pull it,...   Sep 25 2013, 04:31 PM
stugray   The part that I was commenting on was the drip o...   Sep 25 2013, 03:15 PM
Elliot Cannon   The part that I was commenting on was the drip ...   Sep 25 2013, 04:34 PM
SLITS   So, which is better, carbs or fuel injection? N...   Sep 25 2013, 04:44 PM
Elliot Cannon   So, which is better, carbs or fuel injection? ...   Sep 25 2013, 10:40 PM
SLITS   I would have told you that your guess at a crack v...   Sep 25 2013, 04:37 PM
r_towle   I would have told you that your guess at a crack ...   Sep 25 2013, 07:41 PM
Elliot Cannon   I would have told you that your guess at a crack...   Sep 25 2013, 10:36 PM
Dave_Darling   ... supervise you while you waited for the leprec...   Sep 25 2013, 11:13 PM
Elliot Cannon   ... supervise you while you waited for the lepre...   Sep 26 2013, 10:34 AM
SLITS   [quote name='Dave_Darling' post='1932012' date='S...   Sep 26 2013, 11:17 AM
Elliot Cannon   I would have told you that your guess at a crack ...   Sep 25 2013, 10:32 PM
StratPlayer   Time for a six elliot :beer1:   Sep 25 2013, 08:14 PM
Elliot Cannon   Time for a six elliot :beer1: I'm working on...   Sep 25 2013, 10:37 PM
Dave_Darling   I thought he was from the Coast, not from Vegas...   Sep 26 2013, 04:17 PM
r_towle   Guinness and scotch are not made from meat, right?...   Sep 26 2013, 04:20 PM
Elliot Cannon   OMG, I went to bed last night and the Leprechauns ...   Sep 26 2013, 05:31 PM
r_towle   Undercoating.   Sep 26 2013, 05:48 PM
Elliot Cannon   Undercoating. It will be painted with VHT. Work...   Sep 26 2013, 10:20 PM
stugray   nice job! I have said many times that you can ...   Sep 26 2013, 08:19 PM
Elliot Cannon   nice job! I have said many times that you can...   Sep 26 2013, 10:25 PM
Dave_Darling   Inspect the head first. Look over it carefully to...   Sep 26 2013, 10:40 PM
Elliot Cannon   These valve guides just don't look right and m...   Sep 26 2013, 10:42 PM
stugray   If you cant tell a :stir: :poke: when you see ...   Sep 26 2013, 10:49 PM
Elliot Cannon   If you cant tell a :stir: :poke: when you see...   Sep 26 2013, 10:56 PM
stugray   The inside of those heads look too clean for some ...   Sep 26 2013, 10:58 PM
Elliot Cannon   The inside of those heads look too clean for some...   Sep 26 2013, 11:03 PM
stugray   Got it! I actually thought we had a pretty ...   Sep 26 2013, 11:00 PM
Elliot Cannon   Got it! I actually thought we had a pretty...   Sep 26 2013, 11:11 PM
stugray   When I first said: I didnt realize that you had...   Sep 26 2013, 11:40 PM
Elliot Cannon   Both head vents are connected to a breather and I ...   Sep 27 2013, 12:00 AM
euro911   I would go through both heads. It will help to ass...   Sep 27 2013, 01:37 AM
SLITS   Most engines that use guides, the guide for the va...   Sep 27 2013, 06:28 AM
bulitt   Slits has it. The guide has moved in the head. Eit...   Sep 27 2013, 06:45 AM
rhodyguy   remove, straighten, and 'pretty up' the en...   Sep 27 2013, 07:14 AM
lsintampa   IDK, If the valve guide were leaking, it would s...   Sep 27 2013, 10:26 AM
stugray   If the valve guide is loose and leaking, that wi...   Sep 27 2013, 11:04 AM
914_teener   I am with Mark......, Elliot.... I'd do both ...   Sep 27 2013, 12:04 PM
Elliot Cannon   I am with Mark......, Elliot.... I'd do both...   Sep 27 2013, 12:18 PM
SLITS   You two should get a room. Can I pick on you now ...   Sep 27 2013, 01:31 PM
Elliot Cannon   You two should get a room. Can I pick on you now...   Sep 27 2013, 07:02 PM
r_towle   It looks like it moved. I would re-ring it, but th...   Sep 27 2013, 02:01 PM
76-914   :poke: Damn Ron, you gonna let that "rela...   Sep 27 2013, 04:57 PM
Elliot Cannon   Mid-rise lift makes a good work bench.   Sep 27 2013, 07:03 PM
Elliot Cannon   I hope I remember how all this shit goes back toge...   Sep 27 2013, 07:05 PM
Elliot Cannon   Both the rocker arm assemblies are totally clean. ...   Sep 27 2013, 07:07 PM
SLITS   When you pull the rocker assemblies get 8 each 5/1...   Sep 27 2013, 08:54 PM
Elliot Cannon   When you pull the rocker assemblies get 8 each 5/...   Sep 27 2013, 11:50 PM
Eric_Shea   Paint the rest of it yellow...   Sep 28 2013, 12:02 AM
euro911   I hope you tagged your push rods, and if you pull(...   Sep 28 2013, 02:50 AM
SLITS   I hope you tagged your push rods, and if you pull...   Sep 28 2013, 08:52 AM
Eric_Shea   So we've heard... <_<   Sep 28 2013, 09:46 AM
euro911   ... and it's a blue flame, or so I've hear...   Sep 28 2013, 09:59 AM
NORD   Elliot; Make sure when you disasemble that you use...   Sep 28 2013, 11:30 AM
SLITS   That is the problem with using RTV in areas where ...   Sep 28 2013, 09:25 PM
Elliot Cannon   I finally got the head off. These are cylinders ...   Sep 30 2013, 05:00 PM
Elliot Cannon   The cylinder walls look pretty good to me. I can...   Sep 30 2013, 05:02 PM
Elliot Cannon   I pulled out one of the ceramic valve lifters. Af...   Sep 30 2013, 05:05 PM
Elliot Cannon   I'll be pulling the other head off soon and fi...   Sep 30 2013, 05:10 PM
StratPlayer   Elliot are those 94 or 96mm pistons?   Sep 30 2013, 06:59 PM
Elliot Cannon   Elliot are those 94 or 96mm pistons? 96 pistons ...   Sep 30 2013, 09:20 PM
SLITS   Not much wear .... you can still see the cross hat...   Sep 30 2013, 08:01 PM
r_towle   Can you see the valve guide on the vale in questio...   Sep 30 2013, 09:23 PM
Elliot Cannon   It has dual springs and I can't see anything.   Sep 30 2013, 09:25 PM
72hardtop   Whoever used RTV needs to be tarred and feathered ...   Nov 11 2013, 02:33 PM
stugray   :popcorn:   Nov 12 2013, 12:28 AM
72hardtop   What P/C set was used? Any idea? The following sh...   Nov 12 2013, 01:41 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:07 AM
