Rear Defrost Wiring, How's it routed? |
McMark |
Dec 16 2004, 12:38 AM
Just got a factory rear defrost wiring harness. Which reminds me, I should take a picture of it. (IMG:style_emoticons/default/idea.gif) ANYWAY, I assume the wires routed through the L-shaped grommet/tube that goes between the bottom of the firewall and the front engine shelf. Am I right?
Bleyseng |
Dec 16 2004, 08:39 AM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
nah, if it passes thru the firewall how would you hook it up to the rear window? The rear window has two connectors glued on it so the wires need to come up the cabin side of the firewall.
Geoff |
ClayPerrine |
Dec 16 2004, 08:47 AM
Life's been good to me so far..... Group: Admin Posts: 15,463 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
QUOTE(Bleyseng @ Dec 16 2004, 08:39 AM) nah, if it passes thru the firewall how would you hook it up to the rear window? The rear window has two connectors glued on it so the wires need to come up the cabin side of the firewall. Geoff The defroster harness follows the factory wiring harness. It has to go into the engine compartment because it connects to the relay board. |
Lo-Fi Version | Time is now: 15th May 2024 - 09:20 AM |
