Cold start valve, Test |
BarberDave |
Dec 16 2004, 07:30 AM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
Is there a way to test the fuction of the cold start valve? Ans. here or E-mail ,P.M. go to spam file ,???? don,t know why? Thanks Dave (IMG:style_emoticons/default/mueba.gif) |
freezing14 |
Dec 16 2004, 07:43 AM
freezing14 Group: Members Posts: 435 Joined: 21-June 04 From: brockville , Ontario, Canada Member No.: 2,233 |
the easiest way to test is to take it out of the plenum and put 12 V on it,, it should click and if you have a source of compressair , connected to it ,, it will blow air,, be sure to check your cold start valve sensor mounted under the plenum, it is a temperature sensitive switch to ground, , you should have continuity if it is colder than -10C and no contact over 0C
Lo-Fi Version | Time is now: 28th April 2024 - 08:37 PM |
