SOLD- 1970 914 - 2270cc, SOLD! Thanks! |
Mike D. |
Sep 28 2013, 05:15 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
SOLD!!
July 6, 2018 LAST CHANCE BUMP BEFORE CAR GOES TO PAINT $11000. If you want it your color get it now, in a couple of weeks it will be 1970 Adriatic Blue and a heck of lot more expensive $$ I've been driving the car around about once a month and it pulls like crazy. I'll even do a valve adjustment before you pick up. Drivetrain has less than 5k miles, and No Leaks! Engine - 2270 - built from Raby Kit All Machine work and balacing performed by European Motorworks in El Segundo. 1.8 Case clearanced for Raby counter balanced stroker crank H beam Rods Keith Black 96mm pistons stock 2.0 heads with dual springs, 1.7 rockers with 911 adjusters Chromolly pushrods, Duel 40mm Dellorto Carbs. Lighted flywheel, and balaced with presure plate 2.0 heat exchangers and New Bursch Muffler (April-18) Mallory Distributor and 6AL HyFire electronic ignition New Optima Red Top Battery Transmission is later side shift rebuilt with new 1st and 2nd syncros and all seals replaced. Shifter and linkage all sourced from swaps. All new shift bushings from Pelican Parts. Stock Brakes and 4 lug suspension all gone through. New tie rod ends and ball joints, New KYB shocks. Take this car and make it your own with Paint color and interior. Call or e-mail for more pics or questions! Would possibly separate engine if someone is interested. Let me know. (IMG:http://www.914world.com/bbs2/uploads_offsite/i936.photobucket.com-85-1380410121.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i936.photobucket.com-85-1380410121.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i936.photobucket.com-85-1380410122.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i936.photobucket.com-85-1380410123.4.jpg) This side had some work done but you can't tell, which is good... (IMG:http://www.914world.com/bbs2/uploads_offsite/i936.photobucket.com-85-1380410123.5.jpg) |
Atech |
Nov 7 2018, 12:34 PM
Newbie Group: Members Posts: 32 Joined: 29-July 15 From: Nj Member No.: 19,008 Region Association: North East States |
Lo-Fi Version | Time is now: 29th April 2024 - 06:43 AM |
