Subaru Transmission Cable Linkage, Some Photos with a Rule |
DBCooper |
Oct 6 2013, 02:21 PM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
I can't find the thread now, but I promised some photos of my Subaru cable linkage, with a rule for dimensions. Seem to be several projects getting to this point, so hopefully it will be helpful. I wrenched my back so it's been slow, sorry, but here are a few.
General layout. The cable going through the center of the photo is anchored on the left at the sheath to the main bracket, then connects to the shift rod bracket on the right, attached to the shift rod coming out of the transmission. That cable is the shift rod in and out. The rotational cable connects to the bottom of that same shift rod bracket, on the right. The main bracket is the important piece, it locates all the cable sheath anchors. This is the best view of the reinforcing gusset that keeps everything stiff. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.1.jpg) Same view from below and a little further back so you an see the cable sheath mount for the rotational cable. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.2.jpg) Same direction of view, but a little around the main bracket so you can see the shift rod bracket. That's the important dimension for full throw of the MR2 shifter, 8.5cm from the center of the shift rod to the cable heim center. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.3.jpg) Another, that same bracket and dimension. This is the best view of now that bracket attached to the transmission shift rod: (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.4.jpg) Same components, different view. The main bracket curves out from the transmission mount to put the sheath attachment point out in the same plane as the shift rod. In the photos above you can see the shift rod bracket is bent in toward the rear of the transmission to keep that cable movement in the same plane. You can also see more of the main bracket gusset (that triangular shape). Need that gusset to keep it all stiff, minimize cable shifter "mush". (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.5.jpg) Different view, same stuff. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.6.jpg) Shows the main bracket size. This isn't a critical dimension, but it will give some perspective, maybe help. that 5" measurement is from the point where it attaches to the transmission to the cable sheath anchor tab for the rotational cable. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.7.jpg) No, this is NOT Andy's camera, it's my sore back. Not a critical dimension so it's OK. It's 17cm, the distance between the mounting tab for the in-out cable sheath to the middle of the in-out heim joint on the transmission rod bracket. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.8.jpg) Layout (during the build) of the modified MR2 shifter inside the car. That verticall piece of flat stock between the cables from the shifter to the sheath mounting tabs makes the whole thing stiffer, eliminating a lot of the movement and making the feel a lot more precise. Note that there are adjustments everywhere in the system, every cable end. There's also a video of the shifter working in my build thread, ink in the sig, below. And last but really first, your reward for reading this far, my little hot rodder grandaughter. She just wants to have fun. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1381090895.9.jpg) Sorry things are dirty, but this is how things look with 20K miles of road grime. No maintenance done so far other than regular oil changes and a set of tires. If anyone has any questions or you want to see more or different photos just let me know. |
IM101 |
Oct 13 2013, 10:11 PM
Member Group: Members Posts: 264 Joined: 9-November 10 From: Boise Idaho Member No.: 12,367 Region Association: Pacific Northwest |
DB,
Cool, I think that'll be the way I go then... Shouldn't be too hard to adapt your design around the cradle system, and with the shape of the pieces I'll probably be able to draft them in a way where I wont need a fixture to weld it a big plus (IMG:style_emoticons/default/smile.gif). As for the job, really just looking to get onto a sales team, some cool tech or software firm would be ideal. At this point though, just looking for something with a salary and health benefits. Looking back, engineering would have been cool, I just never liked academics, math especially and engineering is all about the math haha. don't get me wrong, I love knowledge acquisition but just could never get into the classroom setting... Anyway here is my linkedin if anyone has any random leads in Boise (IMG:style_emoticons/default/smile.gif) http://lnkd.in/s5KCRJ Chris: As tempting as it is to do advance deposits, I don't think I will. I've just seen it go sideways too many times, even personally... Remember the axles that were supposed to take 3 weeks, but ended up taking what 4 months for the manufacture to get to me, no thanks (IMG:style_emoticons/default/smile.gif). I should have enough to do a production run on these without too much problem. |
DBCooper |
Oct 23 2013, 07:50 PM
DB, Cool, I think that'll be the way I go then... Shouldn't be too hard to adapt your design around the cradle system, and with the shape of the pieces I'll probably be able to draft them in a way where I wont need a fixture to weld it a big plus (IMG:style_emoticons/default/smile.gif). Just to be clear, I'm thinking that means you intend to do this, so I haven't done anything more. If that's wrong let me know. And if you want more information, for example me taking the brackets off the car and photographing with dimensions or whatever, just let me know. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:26 AM |
