Vinyl sails, Fitting vinyl sails |
cal914 |
Oct 20 2013, 10:37 AM
Member Group: Members Posts: 319 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None |
When fitting the vinyl sails where does the vinyl finish when it meet's the trim at the bottom of the sail [any pics would be great and any tips on fitting these sails would be much appreciated ]
gunny |
Oct 20 2013, 10:44 AM
Member Group: Members Posts: 205 Joined: 17-October 12 From: Madison Al Member No.: 15,051 Region Association: South East States |
I aligned mine to the bottom of the trim holes. It allowed for the trim to cover the end and gives a little room for shrinkage.
JawjaPorsche |
Oct 20 2013, 10:51 AM
I did dry fit several times which allows plenty at the bottom. After gluing vinyl on I put chrome trim on at bottom then marked with marker "below" trim then cut. This allows for shrinkage! George would be proud. I put masking tape below holes so glue would not get on paint.
http://76.162.11.251/tuck/sailvinyl.htm |
cal914 |
Oct 20 2013, 01:48 PM
I did dry fit several times which allows plenty at the bottom. After gluing vinyl on I put chrome trim on at bottom then marked with marker "below" trim then cut. This allows for shrinkage! George would be proud. I put masking tape below holes so glue would not get on paint. http://76.162.11.251/tuck/sailvinyl.htm |
JawjaPorsche |
Oct 20 2013, 02:05 PM
I did dry fit several times which allows plenty at the bottom. After gluing vinyl on I put chrome trim on at bottom then marked with marker "below" trim then cut. This allows for shrinkage! George would be proud. I put masking tape below holes so glue would not get on paint. http://76.162.11.251/tuck/sailvinyl.htm You are very welcome Mate! Good Luck! (IMG:style_emoticons/default/biggrin.gif) |
t collins |
Oct 20 2013, 03:23 PM
Advanced Member Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
Look up in the right hand corner of this page for "914 info" and then click on "technical info" Eric Shea did a step by step for sail vinyl installation.
Lo-Fi Version | Time is now: 15th May 2024 - 11:12 PM |
