FS: A/C Compressor Kit, Mounts to top of Engine |
dlee6204 |
Oct 21 2013, 10:44 AM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I'm offering for sale a complete kit in order to mount an A/C compressor on top of the motor which requires no cutting to the engine shelf. I've been running a similar setup for some time with good results. (See this thread here : http://www.914world.com/bbs2/index.php?showtopic=192917) The compressor mounts directly to a non-smog engine fan shroud with no cutting or drilling.
This kit includes: Compressor Mount Puller Adapter Plated Pulley Hardware Belt A few notes: -The compressor is currently set up to run R12. In order to run R134 the oil in the compressor needs to be changed out. I can do this for the cost of oil. -The compressor fits without any major cutting or drilling however there may be interference with the engine bay insulating pad so minor modification to the pad may be necessary. -A swivel allen wrench will be necessary to install the pulley adapter. -Cosmetically the welds didn't come out perfect as I would have liked so if I make any more, they will be at a slightly increased price. This mount is still 100% functional as is. -This kit, in theory, can be mounted with the engine in the car with the removal of the front tin. Price: $360+Shipping If you have any questions, just ask. (IMG:style_emoticons/default/beerchug.gif) |
BeatNavy |
May 3 2020, 02:07 PM
I think the scoop is a kind of a non-issue. The condenser has a pretty good size fan to push (or pull?) air across it, so I'm not sure how much of it requires air movement under the car.
I've got a similar setup from a shop I worked with in Las Vegas (can't remember their name). I haven't been driving my car in work clothes in the summer as much and I'm really hesitant to start cutting up the frunk. I've had it on the shelf for almost 2 years now. |
Lo-Fi Version | Time is now: 2nd May 2024 - 11:03 PM |
