FS: A/C Compressor Kit, Mounts to top of Engine |
dlee6204 |
Oct 21 2013, 10:44 AM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I'm offering for sale a complete kit in order to mount an A/C compressor on top of the motor which requires no cutting to the engine shelf. I've been running a similar setup for some time with good results. (See this thread here : http://www.914world.com/bbs2/index.php?showtopic=192917) The compressor mounts directly to a non-smog engine fan shroud with no cutting or drilling.
This kit includes: Compressor Mount Puller Adapter Plated Pulley Hardware Belt A few notes: -The compressor is currently set up to run R12. In order to run R134 the oil in the compressor needs to be changed out. I can do this for the cost of oil. -The compressor fits without any major cutting or drilling however there may be interference with the engine bay insulating pad so minor modification to the pad may be necessary. -A swivel allen wrench will be necessary to install the pulley adapter. -Cosmetically the welds didn't come out perfect as I would have liked so if I make any more, they will be at a slightly increased price. This mount is still 100% functional as is. -This kit, in theory, can be mounted with the engine in the car with the removal of the front tin. Price: $360+Shipping If you have any questions, just ask. (IMG:style_emoticons/default/beerchug.gif) |
friethmiller |
Feb 26 2021, 08:28 AM
Member Group: Members Posts: 464 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
Update: my engine had some clearance issues after Fat/Rimco cleared the case. Standup folks out there. Ended up sending it back to them and had them build the entire engine to make it right. Engine is arriving Mar 2nd. Need to get back to the A/C pulling and bracket stuff. Does anyone have any updated info on possibly acquiring the mount and pull system? Or, at least the specs so I start fabricating these parts. Thanks in advance.
Lo-Fi Version | Time is now: 3rd May 2024 - 03:29 AM |
