1976 914 2.0, The project continues on |
colingreene |
Oct 31 2013, 12:23 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
Thought I would introduce myself here, My name is Colin.
This is one of the first and most informitive 914 forums i found. Having grown up with the automotive forum culture i figured i would show you all what i bought. I just picked up a 1976 914 2.0 for 500$ seriously. Problem is as you can see in this picture. (IMG:http://www.914world.com/bbs2/uploads_offsite/i821.photobucket.com-16526-1383243790.1.jpg) It needs a bit of work. the previous owner used this car as a daily driver till the clutch delaminated. he then removed the motor took the trans appart and well, lost interest. his mess is now my problem However it could be worse, its a clean straight car and its got most if not all of its paint on it. While the trans was apart i took it to my local and trusted trans shop but came back with a bill for 1725 to replace all the bearings and synchros. Ouch. (IMG:http://www.914world.com/bbs2/uploads_offsite/i821.photobucket.com-16526-1383243790.2.jpg) then started tearing the motor down to clean the tin and probably powder coat it. this car will bankrupt me. The previous owner said that it ran great and had no leaks. Right. (IMG:http://www.914world.com/bbs2/uploads_offsite/i821.photobucket.com-16526-1383243790.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i821.photobucket.com-16526-1383243790.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i821.photobucket.com-16526-1383243790.5.jpg) Also came with these wheels (IMG:http://www.914world.com/bbs2/uploads_offsite/i821.photobucket.com-16526-1383243791.6.jpg) My friend bought one also (A 71) for 500$ heres the two of them together (IMG:http://www.914world.com/bbs2/uploads_offsite/i821.photobucket.com-16526-1383243791.7.jpg) Ive read so many threads to inspire me to get off my ass and do something with my car so hopefully i can take the things i have learned here and really apply it. I only have a few questions i cant find the answers to so ill just throw it out there. Should i bother keeping the stock fuel injection if i want to have some sembalance of performance. and will the stock fuel injection take to being modified say, headers maybe a mild cam? How will the car perform stock ish, while the motor is out is there any must do jobs? Ive been looking at re enforcing the trailing arms and potentially the brackets for them. as well as adding the J west shifter stuff. the shocks and such will need to be replaced, any recommendations for a road car that id like to just handle well, I have one car on race suspension (Ast) and i don't know that i want another one. And what material is the fan housing, is it aluminum or magnesium, can i get it anodized to protect it? The car has been sitting for 10 years so the brakes are slightly borked, worth it to keep the stock calipers or do they need an upgrade. other than that the car only has mild rust here and there ( the hell hole is good the battery tray is mediocre) and it appears that i might have wound up with a decent car. Thanks for all the help in advance i look forward to getting this poor car back on the road. |
colingreene |
Dec 22 2013, 03:38 AM
Local shop in california known well for its type 4 work.
They told me 3 out out of 4 spark plug holes were damaged and needed to be repaired so that was around 300 and all 4 exhaust ports were cracked so that was another 300 plus as well as replacing the exhaust studs was another 300. apparently they couldn't be removed conventionally and needed to be drilled and replaced. as well as 50$ each to replace the seats. one of the guide bosses was also trashed as well. All of it adds up to me finding out as much as the previous owner said the car ran great it had numerous problems that were not addressed and he just drove it because it started. Frustrating but too often is the case. Understandable that its a old head and needed work but it was just more than what i was comfortable with paying as soon as i found out the heads were cracked. ill have to pm the guy in the link for the heads but its highly likely ill work something out with euro 911 as i have bought stuff from him before and hes local so it works great for both parties. I know him to be a solid guy. Some other stuff transpired where I now have a 78mm stroker crank so ill probably use that if i have it. Id rather do a 6 but either way its going to cost a ton. a 2270 should run ok. And I am set on the transmission, I just got it back today. Finally. its nice and tight and ready to go when ever i get my pile of parts together. |
Lo-Fi Version | Time is now: 27th April 2024 - 01:19 PM |
