LOCATED :914-6/911 torsion bar adjusters w/bolts, Wonder where I put mine... |
mr914 |
Nov 7 2013, 03:36 AM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
I need a pair of torsion bar adjusters/end caps for 911/914-6
The splines as these are different than the 4 cyl splines Porsche part #90134103300 #20 & 21 in photo, 22 if you have it also. Attached image(s) |
andrew15 |
Nov 7 2013, 08:47 AM
Newbie Group: Members Posts: 40 Joined: 10-April 10 From: Thunder Bay, ON Member No.: 11,594 Region Association: None |
I need a pair of torsion bar adjusters/end caps for 911/914-6 The splines as these are different than the 4 cyl splines Porsche part #90134103300 #20 & 21 in photo, 22 if you have it also. I have a pair of these for $30 shipped to MI (2x parts 20 & 2x 21 - no 22) Regards, Andrew M |
carr914 |
Nov 7 2013, 12:47 PM
Racer from Birth Group: Members Posts: 118,580 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I need a pair of torsion bar adjusters/end caps for 911/914-6 The splines as these are different than the 4 cyl splines Porsche part #90134103300 #20 & 21 in photo, 22 if you have it also. I have a pair of these for $30 shipped to MI (2x parts 20 & 2x 21 - no 22) Regards, Andrew M That is a Smoking Deal as New Ones from Porsche are only Stocked in Germany! #22 is only a Gasket |
Lo-Fi Version | Time is now: 14th May 2024 - 01:08 AM |
