F&R a-arm mounts, which end is up? |
kdfoust |
May 25 2003, 09:02 PM
Senior Member Group: Members Posts: 694 Joined: 2-January 03 From: Riverside Member No.: 71 Region Association: Southern California |
I'm putting the front suspension back together and I dont' remember which end of the mounts goes up. Is the side that's up here the side that contacts the underside of the car?
Thanks, Kevin Attached image(s) |
914Timo |
May 26 2003, 06:28 AM
******* Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe |
Oh yes, I did. But I havent yet drive it after that.
Well..... I dont know what I should say about them. At least I can tell the installation is not bolt on. One end of A-arm I had to hone a little. It was too tight before that. The others were ok. The most difficult and real PITA was to line the front and rear mounts. First I just bolt everything together. It was a big surprise to notice that after tightening the front mount, The A-arm didn move at all. It was really "solid" suspension ..... (IMG:style_emoticons/default/mad.gif) I need to put some shims between the body and the front mounts. It help a little. The final adjustment I did twisting the front mountings. The front edges of the mountings were too low and the bushings didnt align with the A-arm. I made a tool and twisted firs the mounting points a litle So little that I couldnt see or feel any differences before puting everyting back together again. A little by little I twisted and tested them. Now the A-arms moves quite nicely. And for those who thinks that my front mounting points were dirty or rusted or my car is crashed, I have to show this pic. I beleve that they have not lined them in the factory well enough for bronze bushings. The original rubber bushings allow a lot more missalignment. So, be carefully with those bronze bushings and bearings. Attached image(s) |
Lo-Fi Version | Time is now: 10th May 2024 - 08:51 AM |
