3D printing VS machining |
Mikey914 |
Nov 9 2013, 02:11 PM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes 3D printing can do some pretty cool things, but if you need more than 20, you might as well machine them.
Below is another project I just completed for someone that went down this path. You can also get some more exotic finishes ranging from Teflon to etches. Right now it's nifty, and may work for prototyping, but not practical for manufacturing. I've been watching this field closely, and at some point it may, but right now not so much. Attached thumbnail(s) |
Mikey914 |
Nov 9 2013, 02:13 PM
one more
Matt Romanowski |
Nov 9 2013, 03:18 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
One of the neat areas where it is being used is for mold patterns. You can print a part, then cast it (sand, investment, etc.) and save a lot of work/time.
jpnovak |
Nov 9 2013, 10:54 PM
They call me "Nanoman" Group: Members Posts: 231 Joined: 26-August 09 From: Austin TX Member No.: 10,736 Region Association: Southwest Region |
The part on the right looks familiar.
I agree with these statements. I have found that my 3D printer works great for checking fit on prototypes. Then the files get sent out for metal cutting. Saves me time and money on prototyping. |
McMark |
Nov 10 2013, 12:07 AM
Those are mine, and Jamie did the prototyping. I'll weight in to say that Mark is right, but I think there's more worth mentioning.
1. The prototype pictured did exactly what I needed it to. It got me a quick and accurate sample to confirm that the idea was worth pursuing. 2. The prototype pictured previously is from a home/DIY machine. There are commercial machines out there that make far more detailed pieces such as this: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.3dfuture.com.au-419-1384063630.1.jpg) But clean, professional looking parts are far better produced from billet aluminum. In that sense, Mark is absolutely correct. Bang for the buck at this point is still heavily in the CNC camp. Thanks for the AWESOME looking parts Mark. You are a great asset to the community. |
jd74914 |
Nov 10 2013, 10:26 AM
One of the neat areas where it is being used is for mold patterns. You can print a part, then cast it (sand, investment, etc.) and save a lot of work/time. (IMG:style_emoticons/default/agree.gif) We 3D print parts for sand casting mold patterns all of the time. It is very handing because no real man-hours are spent printing the parts and for the fact that it is trivial to add the correct draft angles. Adding 1-2 degree draft angles on flat faces of a CNC'd part can be very time consuming. After 3D printing a part, you just need to sand it down (usually ABS SLA is used for cost) and sent it to the casting house. If I can find them I'll post up some pictures of racecar uprights which were made using this process and the cast in magnesium. |
GeorgeRud |
Nov 10 2013, 10:44 AM
As a recognized 'old fart', this technology just blows me away! I imagine that more and more NLA and obscure parts may be able to be reproduced using these printers.
Glad to see folks working with these, and hope that we may be able to start producing more things back at home rather than relying on overseas suppliers all the time (Sorry for the political implications). |
Matt Romanowski |
Nov 11 2013, 07:03 AM
If you don't think 3D printing is going to make production parts, check this out. http://www.thefirearmblog.com/blog/2013/11...al-1911-pistol/
Printed metal that stands up to a pretty high level of abuse/use. |
Zimms |
Nov 11 2013, 07:05 AM
Senior Member Group: Members Posts: 1,413 Joined: 11-February 06 From: Michigan Member No.: 5,565 Region Association: Upper MidWest |
But clean, professional looking parts are far better produced from billet aluminum. In that sense, Mark is absolutely correct. Bang for the buck at this point is still heavily in the CNC camp. (IMG:style_emoticons/default/agree.gif) but I expect the ebeam and DMLS machines to be integrated into conventional subtractive processes over the next 10 years. GE is making fuel nozzles for it's next generation of engines using additive, taking an assembly of 18 components down to 1, and reducing the weight by 25%. The large turbine builders all have their fingers in this because they can start to design parts that cannot be machined, or machined easily, for better weight savings. GE nozzle |
Mikey914 |
Nov 11 2013, 07:26 AM
Correct, we are looking at bringing DLS into the machine shop specifically for a high end customer with needs to make only a few parts, but with high tolerances, in stainless.
biosurfer1 |
Nov 11 2013, 09:57 AM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
I imagine 3D printing is in the "dot matrix" age relative to it's regular printing counterpart...imagine what 3D printing will do once it gets to the "color laser" phase and beyond.
Zimms |
Nov 11 2013, 10:57 AM
Correct, we are looking at bringing DLS into the machine shop specifically for a high end customer with needs to make only a few parts, but with high tolerances, in stainless. Who are you looking at? EOS? I think I was shocked about the software cost that you need to build the support structures, etc. |
stephenaki |
Nov 11 2013, 11:08 AM
Can I get this one dad?? Group: Members Posts: 1,183 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None |
I was wondering how easy it would be to 3d print a tail light assembly, not the lens portion but the black plastic housing and interior reflector piece. Thoughts? (IMG:style_emoticons/default/popcorn[1].gif)
Matt Romanowski |
Nov 11 2013, 09:03 PM
I was at Staples today and they hhave the Cube units on the shelf. 3D printing is mainstream!
Mikey914 |
Nov 12 2013, 03:30 AM
EOS has the best package I've found so far, yes not cheap.
obscurity |
Nov 12 2013, 07:00 AM
Member Group: Members Posts: 411 Joined: 24-February 06 From: Atlanta ,GA Member No.: 5,628 Region Association: South East States |
Yes 3D printing can do some pretty cool things, but if you need more than 20, you might as well machine them. Below is another project I just completed for someone that went down this path. You can also get some more exotic finishes ranging from Teflon to etches. Right now it's nifty, and may work for prototyping, but not practical for manufacturing. I've been watching this field closely, and at some point it may, but right now not so much. You may have already covered this but what machine/system are you using to make these parts? Just curious John |
Lo-Fi Version | Time is now: 19th May 2024 - 12:36 PM |
