Type IV, Turbo Motor |
Randal |
Nov 10 2013, 10:20 AM
We can get the heads configured to support a turbo, cylinders (nickies), great pistons and quality rods are available and there's a ton of aftermarket turbo stuff readily available now. Looking from the top down, just wondering how much reliable HP you could get out of a type IV? Or maybe it just better to start with a 2.0 or 2.2 (6)?. One guy knows for sure, i.e., Britain built a quality type IV turbo motor for his 912. |
Nov 10 2013, 09:46 PM
From what my feeble mind remembers, jake built more than a few turbo type 4 motors.
There was also a guy on shop talk forums named Wally who got over 400 horsepower using it as a drag car, race car, and street car all in a beetle. |
michael7810 |
Nov 11 2013, 01:01 PM
Senior Member Group: Members Posts: 1,080 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
Randal |
Nov 11 2013, 02:06 PM
There you go! |
Woody |
Nov 11 2013, 03:03 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
McMark |
Nov 11 2013, 09:41 PM
I wouldn't go so far as to claim reliability on any turbo motor at this point. So far my Turbo 1.7 has been great, but it's only got 2k miles on it or so.
But I expect, that a 2270 with JE pistons, iron cylinders, and 2.0 heads could be built to get between 250-300 - assuming it's built to still make power down low. Probably 50 more if it were 'peaky'. |
Krieger |
Nov 15 2013, 12:27 AM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I wonder how/if 1.7 heads could be used for a larger 2270. They do have smaller ports that could help with velocity...
HAM Inc |
Nov 15 2013, 08:19 AM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
Big T4's don't want for port velocity. They need flow.
Turbo's increase charge density, and have no impact on velocity. |
Randal |
Nov 15 2013, 07:21 PM
Nov 15 2013, 07:28 PM
Resident German Group: Admin Posts: 41,623 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Please explain the difference between velocity and flow. One is speed the other is volume. Of course in reality it's a wee bit more complicated than that. (IMG:style_emoticons/default/biggrin.gif) |
McMark |
Nov 15 2013, 08:53 PM
A smaller port trades a lower volume of air for a higher speed of air.
A larger port increased the volume, but at a slower air speed. A higher volume of air means more potential for power/combustion, especially at high RPM. A higher air speed means there is better fuel suspension and ignition, especially at low RPM. You trade one for the other. Another in the long list of compromises that IS engine design. In a simple example, street engines would want increased port velocity because they spend most of their time at low RPM accelerating from a stop. Race engines would want increased port flow because their running at high RPM and want as much air ingested for every revolution (air is power). As Len mentioned, compressing the air is different than both of these factors. But forced induction is a little like making a small port act like a big port. |
Randal |
Nov 16 2013, 10:31 AM
There you go! That 2.8 turbo motor would be fun to buy and convert the setup so it'd fit into a 914. Although the 2.8 size would be a weight penalty with SCCA rules in XP. How much to convert that Mark? |
McMark |
Nov 16 2013, 09:01 PM
Sorry to say it, but that looks like the kind of motor you would spend more money 'fixing' than it would cost to build a new one.
-The 1-2 side turbo looks like it'll fit. -The 3-4 side turbo probably won't fit. -The distributor is garbage. -The intakes probably won't clear the engine lid. -Exhaust pipes from the turbos out the back need to be fabbed. -Intake system to the turbos needs to be fabbed. -I wouldn't use the 1.8 exhaust log-pipes on a 2.8. -Hex bar linkages are crap. -Blow-thru carb setups can work, but I wouldn't risk an $8000+ investment on it. -The few FAT performance motors I've heard about were terribly underpowered for the displacement. So I don't have a lot of faith in whoever is designing their engine combos. -There are a lot of little things on that engine that I would have to fix because I wouldn't want my name anywhere near them. i.e. The oil filler tube setup. (IMG:style_emoticons/default/sad.gif) |
Randal |
Nov 17 2013, 09:52 AM
Sorry to say it, but that looks like the kind of motor you would spend more money 'fixing' than it would cost to build a new one. -The 1-2 side turbo looks like it'll fit. -The 3-4 side turbo probably won't fit. -The distributor is garbage. -The intakes probably won't clear the engine lid. -Exhaust pipes from the turbos out the back need to be fabbed. -Intake system to the turbos needs to be fabbed. -I wouldn't use the 1.8 exhaust log-pipes on a 2.8. -Hex bar linkages are crap. -Blow-thru carb setups can work, but I wouldn't risk an $8000+ investment on it. -The few FAT performance motors I've heard about were terribly underpowered for the displacement. So I don't have a lot of faith in whoever is designing their engine combos. -There are a lot of little things on that engine that I would have to fix because I wouldn't want my name anywhere near them. i.e. The oil filler tube setup. (IMG:style_emoticons/default/sad.gif) Reality is a sometimes uncomfortable.... So I take it it's build it or don't get what you want. Hey, I've been through this exercise before. (IMG:style_emoticons/default/smile.gif) |
ConeDodger |
Nov 22 2013, 08:35 AM
Apex killer! Group: Members Posts: 23,577 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
What about your motor Randall? Pull the jugs and pistons, go with low compression forged pistons and Nickies. Have Mark make sparks for a turbo exhaust system. Coil-on-plug crank fired. ITB's and an intercooler then hang on!
Go drive Mark's car then realize, this is a completely stock 1.7 internally that acts like a 2270... (IMG:style_emoticons/default/driving.gif) |
Randal |
Nov 23 2013, 11:17 AM
What about your motor Randall? Pull the jugs and pistons, go with low compression forged pistons and Nickies. Have Mark make sparks for a turbo exhaust system. Coil-on-plug crank fired. ITB's and an intercooler then hang on! Go drive Mark's car then realize, this is a completely stock 1.7 internally that acts like a 2270... (IMG:style_emoticons/default/driving.gif) I really hate to mess with my motor after all the $$ spent. It works and was built by someone who actually knows what he'd doing. Also everything in that motor was carefully procured, checked and or tested before it was assembled. The J&E pistons were rejected 5 times until J&E machined what they were told to do. Also Len Hoffman says that my heads, while great, are not the best for a turbo setup. Also my cam would need to be changed. So probably a build starting from scratch. BTW everyone points to Elgin as the best cam guy around, but would need to figure out which cam would support Hoffman turbo heads best. This unfortunately is a crap shoot that might come out right, but might not and to be honest I don't feel like going on a exploratory journey again. So.... It's pretty easy to look at building a 2.7 or 3.2 liter (6) as there are plenty of folks that have run turbo's porsches and the head/cam combinations are well know. Also the motors are readily available and reasonable. I could run E Mod in SCCA with essential no weight penalty other than the actual weight, if you know what I mean. EMOD would allow up to a 3.2 liter turbo and still the minimum weight would be 1700# with driver. My actual would be more like 1850-1900# with driver. The big deal would be finding a light weight transmission that was strong and shifted fast. A sequential would be nice, but bring $10-15K. I've heard that Subi gear boxes can be converted to work with a Porsche motor and are strong and shift fast, even if they aren't sequential. As far as hill climbs I'd probably have to change classes, but with 300RWHP (conservative) I wouldn't mind running with the big modified cars. Could you imagine what 300+RWHP would be like on a hill? (IMG:style_emoticons/default/flag.gif) |
brant |
Nov 23 2013, 06:07 PM
914 Wizard Group: Members Posts: 11,620 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
don't forget to add another 150lbs of motor weight when calculating going with a -6
what does your 4 car weigh now wet? b |
Randal |
Nov 23 2013, 06:51 PM
brant |
Nov 23 2013, 09:17 PM
don't forget to add another 150lbs of motor weight when calculating going with a -6 what does your 4 car weigh now wet? b 1682# 150# net, really? I can lose 50# with lighter weight wheels; a bit more changing calipers. we are really close in weight I have hit 1826 wet you are about exactly the same if you add 150 yeah its close to 150 the mag case motors can take 20lbs off of that... (the reason I rebuilt with one on the 2nd motor) although f.i. and turbo might add that back I think I could shed 50lbs if I got rid of my metal front/rear hoods... another 50 if I cut the metal fenders, and roof off. Frank Beck's -6 is rummored to be in the 1650 range with his road racer.... of course he out run's GT3's with his 2.5ss, and he is an amazing driver, so you have to have something to shoot for. |
McMark |
Nov 23 2013, 09:18 PM
I wouldn't touch your current motor. I would build something like I did with the 1.7. Something just to prove the concept and the combo. See what it feels like and then decide if it's worth building a real motor.
Lo-Fi Version | Time is now: 6th May 2024 - 07:08 PM |
