> Help! Rebuilt Carbs, Now Engine Car Shudders at 4k RPM
'70PVW914
post Nov 11 2013, 12:07 AM
Post #21
Hey folks. I just rebuilt the weber IDF 44 carbs on my 914-2.0 because I was experiencing hiccups/stutters in acceleration from idle to about 3k rpm. Also, the car would idle very low, and then die if you did not give it a good amount of revs after starting. I figured my idle jets were clogged, and since the carbs had not EVER been rebuilt, I re-gasketed, and rejetted them.
Just finished that today, put in new fuel line to the carbs, changed the fuel filter, and troubleshot a strange problem where my accelerator cable seemed to wrap its way around the clutch cable and bind. :headbanger
After all of that.....my car is STILL acting very strange; in some ways things are better, and in some, things are worse!
NOW:
The car seems to idle just fine at a very nice 900rpm after adjusting the idle and throttle body.----SWEET!
The accelerator cable seems to stick slightly, also, the ball joint for my accelerator pedal seems to keep popping off of the pivot point (Is there a trick to this, or is the ball joint just shot?!) Seem to have it on there now, but now guarantees! ---LESS SWEET
Still seems to stutter when reving in gear b/w idle and 2.5k rpm...same as before I rejetted and cleaned (IMG:style_emoticons/default/dry.gif)
Shudders and looses power at 4k rpm in every gear...this thing had crazy power after 4k before I messed with anything. (IMG:style_emoticons/default/mad.gif)
When I replaced the float needles and seats that came with the rebuild kit, I noticed the seats were way smaller on the rebuild. I DID NOT adjust the float level....my first culprit for this less than stellar performance. After reading some posts on here, it sounds like the float should be at between 12.5mm and 13mm from the upper face of the carb. Would this solve these problems?
Also, I DID remove the throttle valves for a clean and inspection when rebuilding...I am hoping this is not the root of the problem, as they do not seem as smooth as they once were.
Don't think its the resize in jets, as I just changed idles from .45 to .55, and air corrections from 200 to 190 as per recommendation.
Where should I start here!!!????? I figure I will measure and adjust the float tomorrow, after I remove the carbs again (damnit). But if that doesn't work...what should I be trying?.....Damn weber book didn't get here in time and I am not the most patient.....
'70PVW914   Help! Rebuilt Carbs, Now Engine Car Shudders at 4k RPM   Nov 11 2013, 12:07 AM
ThePaintedMan   4K indicates something more towards the top-end of...   Nov 11 2013, 06:48 AM
wndsnd   Not an expert on the carbs yet. Mine are brand ne...   Nov 11 2013, 07:04 AM
Razorbobsr   Not an expert on the carbs yet. Mine are brand n...   Nov 11 2013, 07:10 AM
rhodyguy   confirm the throttle plates are installed with the...   Nov 11 2013, 07:52 AM
'70PVW914   So, in order to sync the carbs, I need to get a sy...   Nov 11 2013, 07:54 PM
stugray   I am local. Work in Boulder, Live in Longmont. If ...   Nov 11 2013, 09:47 PM
'70PVW914   I am local. Work in Boulder, Live in Longmont. If...   Nov 12 2013, 08:36 PM
rhodyguy   i misspoke with the degree number i guess. at leas...   Nov 12 2013, 07:33 AM
Racer Chris   i misspoke with the degree number i guess... I b...   Nov 12 2013, 08:18 AM
rhodyguy   edit. too early.   Nov 12 2013, 08:42 AM
'70PVW914   Ok guys....bad news. I woke up this morning psyche...   Nov 17 2013, 01:18 PM
'70PVW914   That was a joke about the jb weld....   Nov 17 2013, 01:26 PM
wndsnd   I hope you found the piece in the bowl...   Nov 17 2013, 04:04 PM
brant   I actually have seen and used in weld in different...   Nov 17 2013, 04:19 PM
brant   You might even be able to safety wire that   Nov 17 2013, 04:20 PM
Dr Evil   Is that not an integral part of the float? Get a n...   Nov 17 2013, 04:43 PM
euro911   It's a broken split tab, Mike - but repairable...   Nov 17 2013, 06:36 PM
Dr Evil   I am used to mikuni, bing, etc, where that piece i...   Nov 17 2013, 06:55 PM
Dr Evil   Ya, a new float will have that tab. This is what I...   Nov 17 2013, 06:56 PM
ThePaintedMan   That's a very common problem with Webers. Thos...   Nov 17 2013, 07:00 PM
rhodyguy   is this the set you were sent to replace the first...   Nov 17 2013, 07:01 PM
euro911   On Webers, the tabs that the float pivot rod slide...   Nov 17 2013, 07:13 PM
Dr Evil   On Webers, the tabs that the float pivot rod slid...   Nov 17 2013, 07:58 PM
'70PVW914   Thats the spot....theres also this, i posted to th...   Nov 17 2013, 07:50 PM
Racer Chris   The broken leg is a bit too delicate to weld back ...   Nov 18 2013, 05:59 AM
'70PVW914   The broken leg is a bit too delicate to weld back...   Nov 19 2013, 07:02 PM
brant   be careful where you take that for welding its a ...   Nov 19 2013, 07:11 PM
Racer Chris   be careful where you take that for welding its a...   Nov 19 2013, 07:44 PM
brant   There is a certified aluminum welder in longmont.....   Nov 19 2013, 08:06 PM
stugray   Dont know if blurry pics help but this is a view o...   Nov 19 2013, 08:43 PM
stugray   Any luck? Something I forgot to mention. I stumbl...   Nov 22 2013, 03:36 PM
somd914   Not sure if you've been able to get your float...   Nov 23 2013, 10:53 AM
'70PVW914   Hey folks, Got the repair done to the pivot leg a...   Nov 23 2013, 10:10 PM
euro911   Very good :thumbsup:   Nov 23 2013, 10:33 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:11 AM
