Installing Cylinder and Heads, Minimum deck height? |
gothspeed |
Dec 12 2013, 06:51 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Anyone wish to chime in on the minimum deck height on these motors? I'm seeing .030-.045 as the minimum. I believe I went with .035" deck height on my build ...... if that wasn't it, then it was .040" ......... what ever the number was, I recall calculating 8.4:1 static compression ratio at that time, my pistons also had a valve relief that I think was 3 cc of volume ..... (IMG:style_emoticons/default/popcorn[1].gif) |
euro911 |
Dec 12 2013, 07:43 PM
I see were you're getting the extra 2.5cc
If you shimmed the base so the piston aligned flat with the top of the barrel, wouldn't the deck height subtract the area you filled to the brim? |
OU8AVW |
Dec 12 2013, 07:59 PM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
I did mine the same as Stu. The disk is flat across the chamber recess like the cylinder is. I sealed it with grease. I think my heads just have had less machine work done over time than others.
I'll PM Jake and report back. |
euro911 |
Dec 12 2013, 10:11 PM
I didn't realize you had a plate in there. Hard to tell at first glance, but I see it now.
Lo-Fi Version | Time is now: 29th May 2024 - 03:13 AM |
