Blue 75 buld thread, My Laguna Blue '75 build thread |
914skraper |
Nov 16 2013, 08:13 PM
Newbie Group: Members Posts: 36 Joined: 8-October 13 From: Denver Member No.: 16,486 Region Association: Rocky Mountains |
Been a 914 fan since, well, since you could buy one new... Finally got one.
It's in Like New shape! Except for the rust I found, and the rust I haven't found, and the engine fire, and the half-repaired wiring, and the barbequeued top, and the barbequeued seats, and the missing parts, and the carbed mystery motor, and the body damage, and the PO's hellhole fix, it could have just driven off the showroom floor! (IMG:http://www.914world.com/bbs2/uploads_offsite/i199.photobucket.com-16486-1384654393.1.jpg) |
914skraper |
Nov 16 2013, 08:17 PM
After the mandatory couple of weeks of futzing around, sitting in it and making engine noises, I actually picked something and got started... I stripped the trim and roasted vinyl off the roll bar and started cleaning up the burned paint.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i199.photobucket.com-16486-1384654656.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i199.photobucket.com-16486-1384654656.2.jpg) |
gothspeed |
Nov 16 2013, 08:20 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Yes, I thought mine was in a lot better shape than it actually was also ...... however after a few years of taking it apart and addressing the 'issues' at a snails pace .... I am hoping to begin reassembly in a couple months ...... but since it has been so many years since I took it apart ..... I have forgotten where most everything goes ..... (IMG:style_emoticons/default/unsure.gif)
BTW (IMG:style_emoticons/default/welcome.png) |
914skraper |
There's a dent in the middle of the drivers-side sail, and I started monkeying with that.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i199.photobucket.com-16486-1384654826.1.jpg) |
Krieger |
Nov 16 2013, 08:23 PM
Advanced Member Group: Members Posts: 4,723 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
(IMG:style_emoticons/default/welcome.png) Welcome to the madness. Glad to see you have a good sense of humor!
ConeDodger |
Nov 16 2013, 08:32 PM
Apex killer! Group: Members Posts: 23,604 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
(IMG:style_emoticons/default/welcome.png) You are wonderfully delusional... It does look like new!
914skraper |
Nov 16 2013, 08:59 PM
"delusional" - yeah, I'd have to cop to that.
I'm not much of a candidate buyer for a new car because they don't come with those features I listed in the first post. (IMG:style_emoticons/default/rolleyes.gif) How the heck are you supposed to forge a link with a car if you can just, you know, drive it? (IMG:style_emoticons/default/w00t.gif) |
Mike Bellis |
Nov 16 2013, 09:42 PM
Been a 914 fan since, well, since you could buy one new... Finally got one. It's in Like New shape! Except for the rust I found, and the rust I haven't found, and the engine fire, and the half-repaired wiring, and the barbequeued top, and the barbequeued seats, and the missing parts, and the carbed mystery motor, and the body damage, and the PO's hellhole fix, it could have just driven off the showroom floor! (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/welcome.png) You'll do just fine here... |
914skraper |
Dec 10 2013, 11:00 PM
Made some progress on the floorboards. Stripped out the "Asphalt Alptraum" stuff and found the floorboards underneath aren't as rusty as I was afraid they might be...
To lift the asphalt stuff, I thought about using dry ice, or about using heat - then just went out on a cold day and lit into the stuff with a putty knife. (IMG:style_emoticons/default/smash.gif) Some of it came up in hand-sized sheets, some had to be hammered out in tiny shards, and some is still there waiting for my wire wheel, but most of it came out. Yes that's the driver's rocker carpet still there, still trapped by the handbrake lever. I got the lever off its pivot but haven't yet gotten the cable out of the lever, and I'm not yet to the point of slicing the carpet to free it. (IMG:http://www.914world.com/bbs2/uploads_offsite/i199.photobucket.com-16486-1386738047.1.jpg) |
914skraper |
Dec 10 2013, 11:06 PM
Some rust, no holes that I found so far. Current plan is to use a wire cup on an angle grinder to rip the rest of the asphalt and seam-sealer out, and to get as much of the surface rust off as possible. Then, douse it with phosphoric acid to eat the rest of the rust, and apply a flexible sealer/insulator goop.
What's Standard Operating Proceedure - do I remove the seat hinge brackets before treating the rust? Do I remove the seat crossmember thing? (IMG:http://www.914world.com/bbs2/uploads_offsite/i199.photobucket.com-16486-1386738366.1.jpg) |
914skraper |
Dec 10 2013, 11:16 PM
Here you can see the remains of the roasted asphalt along the rear edge of the floor.
What about the trans tunnel - there's a fair amount of rust inside there. I'll search, but what's your opinion: Just dump phosphoric acid in there and let it simmer, then suck it out? Open up the trans tunnel by slicing a "hatch" in the top? Remove the trans hump completely by cutting the spot-welds? What would you do about the rust inside the tunnel? (IMG:http://www.914world.com/bbs2/uploads_offsite/i199.photobucket.com-16486-1386738986.1.jpg) |
ww914 |
Dec 11 2013, 09:41 AM
914 Convert Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
914skraper |
Dec 29 2013, 06:00 PM
Got the rest of the asphalt stuff out, and got the pedal board up. The pedal cluster and surrounding area has rust, but not the biblical mess that I expected.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i199.photobucket.com-16486-1388361608.1.jpg) |
914skraper |
Dec 29 2013, 06:13 PM
And today I finally got a chance to make some progress...
I wasn't sure whether it'd be necessary to pull up the seat hinge brackets to work the rust underneath them, but I finally decided better safe than sorry. Turns out there's a technique to using a spot weld cutter; I holed the drivers floor in a couple of places before I figured it out. But, I got the brackets off, along with the misc tabs and handbrake 'tunnel', then used a cup wheel to knock the rust off the firewall and rear area of the passenger floorboard. In case you're in the same quandary, in this pic the passenger floorboard is on top, and you can see the red rectangular rust patches underneath where the hinge brackets were on the drivers side - the rust has already been brushed off the pass side. (IMG:http://www.914world.com/bbs2/uploads_offsite/i199.photobucket.com-16486-1388362406.1.jpg)[/URL] |
914skraper |
Dec 29 2013, 06:19 PM
I think the strategy going forward will be to finish one section - get the rust brushed off, treat it with a phosphoric acid product to kill any remaining rust, seal the seams with some suitable product, paint, then cover with a sound deadener.
Then move on to the next section - trying to feel like I'm making progress, and I don't want the fresh sections to rust while I wait for my next chance to work. Guess I'll be placing a nice Eastwood order pretty quick. |
wndsnd |
Dec 29 2013, 06:35 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Good job. Looks like a real nice car.
John |
914skraper |
Dec 31 2013, 11:20 AM
914skraper |
Feb 28 2014, 05:46 AM
Ahh, the joys of January and February in the Rockies - too flarkin' cold to do much with my car. I did get some time to get into the passenger door and window, and got suprises both pleasant and otherwise.
The pleasant suprise was that the door was not a ball of rust - actually in really good shape. Here's a view down inside the door, (IMG:http://www.914world.com/bbs2/uploads_offsite/i199.photobucket.com-16486-1393587978.1.jpg) and a view up at the underside of the door: (IMG:http://www.914world.com/bbs2/uploads_offsite/i199.photobucket.com-16486-1393587978.2.jpg) |
914skraper |
Feb 28 2014, 05:50 AM
... yeah so those weren't the most awesome pictures. Anyway, I was happy that the door was rust-free.
The passenger side glass was broken, but the car came with a spare - I thought. Turns out the spare is an "early" window, won't fit my '75. (I'll skip the boring picture of an early side window.) Guess I'll be sourcing a late passenger side window glass. |
76-914 |
Feb 28 2014, 09:37 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Looks to be a nice tub, so far. (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 31st May 2024 - 05:43 PM |
