speedo high beam indicator - wires and socket questions |
jimkelly |
Nov 17 2013, 11:04 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
my 1975 car seems to have a 2 prong plastic type socket, which appears to have an internal connection to the speedo can for ground.
my question is why does this socket have 2 spades? in my 1972 car, the white/green wire was cut and this light was spliced into the regular dash lights but this car seems to use a metal socket that grounds directly to speedo can. I want to revise my wires once again to allow for a high beam indicator light in my speedo. thoughts? should I use a metal or plastic type socket? I know - or think - that some of my lights are in plastic dual spade sockets because they are feed ground thru the ecu - like oil pressure dummy light? thus wondering if there are 2 kinds of plastic sockets? thanks Attached image(s) |
toolguy |
Nov 17 2013, 06:09 PM
Senior Member Group: Members Posts: 1,268 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
metal socket grounds to instruments common ground. . plastic socket = no electrical conductivity therefor it has to have a ground wire connection |
StratPlayer |
Nov 17 2013, 06:15 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
The plastic holders have a metal tab on the side that grounds the holder.
jimkelly |
Nov 17 2013, 06:30 PM
i'm assuming there are at least 2 kinds of plastic sockets, one with ground to can and one that needs ground from ecu.
here also is a pic of a plastic socket without a grounding tab, and this one seems to take a different bulb than other sockets. thanks guys! jim Attached image(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 04:38 PM |
