Carpet Grommets Ghetto install - on the cheap and easy, Bump fro a technique to cut holes in carpet without snagging |
Mikey914 |
Nov 25 2013, 09:29 PM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The problem with retrofitting carpets is cutting the perfectly round hole to install the grommets. So how to cut these without having to sell you a large punch to do the job and ship it to you.
Well, here's a down and dirty way to do this for less than $5. What I did was take a 1" dia piece of threaded pipe and a cap. I ground the one edge to a point, put the cap on the other side and used a hammer and a cutting block to do the following. Any better ideas, post em here! Attached thumbnail(s) Attached image(s) |
Mikey914 |
Nov 25 2013, 09:30 PM
Installed
Attached thumbnail(s) |
cary |
Nov 25 2013, 09:33 PM
MacGyver ..................
euro911 |
Nov 25 2013, 09:41 PM
OK genius, now make one for the foot pedals (IMG:style_emoticons/default/poke.gif)
When you say 1" diameter, is it really 3/4" ID galv pipe? Grommets look good (IMG:style_emoticons/default/smile.gif) |
914work |
Nov 25 2013, 09:58 PM
Member Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None |
Are you gluing them in place?
Mikey914 |
Nov 25 2013, 10:12 PM
They can easily be glued in place with a little rubber cement.
Mikey914 |
Nov 25 2013, 10:16 PM
OK genius, now make one for the foot pedals (IMG:style_emoticons/default/poke.gif) When you say 1" diameter, is it really 3/4" ID galv pipe? Grommets look good (IMG:style_emoticons/default/smile.gif) It's called a scissors. (IMG:style_emoticons/default/biggrin.gif) The problem with the small holes is it's difficult to cut a small hole perfectly. I believe the ID is 1" as it was in the 1" bag and it measures 1". Any 1" dia material will work, as long as you can whack it hard enough to cut cleanly. |
gothspeed |
Nov 25 2013, 11:48 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Wow! Great job and idea! (IMG:style_emoticons/default/smile.gif)
edwin |
Nov 26 2013, 06:00 AM
Member Group: Members Posts: 321 Joined: 20-May 09 From: Australia Member No.: 10,384 Region Association: Australia and New Zealand |
I've found when using a punch like that, hitting against the endgrain of a piece of pine or something similar works best. Also keeps the punch sharper for longer
maf914 |
Nov 26 2013, 07:02 AM
Mark, What did you use to grind the edge of the pipe. That appears to be a pretty smooth bevel edge. Thanks.
69telecaster |
Nov 26 2013, 07:52 AM
Member Group: Members Posts: 101 Joined: 4-April 10 From: White Cloud, MI Member No.: 11,558 Region Association: None |
I've done the same thing with an old holesaw...it's thinner and the better steel will hold a sharp edge longer. Then on the arbor press rather than whacking with a hammer. You still need the wood!
cm |
bulitt |
Nov 26 2013, 08:16 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Reminds me of the old leather punches.
JmuRiz |
Nov 26 2013, 09:03 AM
914 Guru Group: Members Posts: 5,426 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Excellent, nice looking charcoal loop carpet too. I'm sure I'll be in touch this winter with an order
Harpo |
Nov 26 2013, 09:04 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Thanks Mark,
I was wondering how I was going to install those. DAvid |
sbsix |
Nov 26 2013, 10:33 AM
only the lead dog enjoys a change in scenery... Group: Members Posts: 450 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California |
Hey Mark what is the Porsche part number for that tool?
ClayPerrine |
Nov 26 2013, 11:02 AM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Where did you get the grommets?
euro911 |
Nov 26 2013, 11:24 AM
914 RUBBER . COM. Mark has new grommets for the foot pedal area too ...
JmuRiz |
Nov 26 2013, 12:29 PM
Hey Mark what is the Porsche part number for that tool? Model # 310 CA-1 at HDRacing But you'd have to check your local store for the threaded bit. If it was a Porsche part it would be $20 instead of $1.98 (IMG:style_emoticons/default/biggrin.gif) |
sbsix |
Nov 26 2013, 03:44 PM
If it was a Porsche part it would be NLA (IMG:style_emoticons/default/smile.gif)
Mikey914 |
Nov 27 2013, 12:24 AM
Lo-Fi Version | Time is now: 16th May 2024 - 05:52 PM |
