WTB: Heater Control Flappers for 914-6 |
puffinator |
Nov 26 2013, 03:22 PM
Member Group: Members Posts: 193 Joined: 6-August 13 From: Annapolis, MD Member No.: 16,218 Region Association: MidAtlantic Region |
I need the stuff between the heat exchangers and bulkhead. Are the pieces the same for 4s and 6s?
euro911 |
Nov 26 2013, 04:05 PM
IIRC, the control valves for the original 6 were a little different - they had a hole in the top (side) cap. Other than that, they are the same size and work the same.
I just sold the last ones I had, but search the classifieds. Bruce Stone probably has some (IMG:style_emoticons/default/confused24.gif) The other tin ducting is totally different |
bdstone914 |
Nov 27 2013, 12:53 PM
IIRC, the control valves for the original 6 were a little different - they had a hole in the top (side) cap. Other than that, they are the same size and work the same. I just sold the last ones I had, but search the classifieds. Bruce Stone probably has some (IMG:style_emoticons/default/confused24.gif) The other tin ducting is totally different I have the 914 type flappers. Extra hole in the -6 vents more hot air when not in use. |
Lo-Fi Version | Time is now: 16th May 2024 - 08:25 AM |
