Piston oil squirters for a /4...anyone have them? |
Mueller |
May 26 2003, 02:20 PM
Is the 150 dollar bill worth it? Would I need an external oil-cooler for sure since the oil would be hotter than normal without piston squirters?
McMark |
Oct 26 2014, 12:31 PM
Check valve opens around 20psi.
Attached image(s) |
r_towle |
Oct 26 2014, 06:23 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Check valve opens around 20psi. Umm, not always (IMG:style_emoticons/default/smile.gif) So a friend came over today to try and get some squirters functioning, seems they get clogged or just stop opening... Looks like a tough thing to fix, it's drilled in, then it looks like the squirters are peeled over in the 911 case.... I wonder, are there any threaded ones out there? Mark, thanks for that pic, please document this mod, I will be doing it when I pull the motor apart this winter.....cause I just can't leave it alone, and I need to change out the camshaft.....so while I am in there, this seems like a very good idea to help out. Rich |
Lo-Fi Version | Time is now: 26th May 2024 - 11:08 PM |
