Piston oil squirters for a /4...anyone have them? |
Mueller |
May 26 2003, 02:20 PM
Is the 150 dollar bill worth it? Would I need an external oil-cooler for sure since the oil would be hotter than normal without piston squirters?
Mark Henry |
Oct 26 2014, 06:42 PM
I've cut notches in rods, I'd say it likely slings rather than squirts, but oil pressure has always been fine and I'm guessing it helps.
I've also replaced 911 squirters, it not a hard job at all, just on the wallet, those puppies are about $50 ea IIRC. Make sure you test them first they are likely fine. They can stick open or closed, seafoam or MEK will often free them up. Careful with MEK if you use it, nasty stuff. I don't really like the squriter in rod mod, I wouldn't do it. |
Lo-Fi Version | Time is now: 26th May 2024 - 09:19 PM |
