Piston oil squirters for a /4...anyone have them? |
Mueller |
May 26 2003, 02:20 PM
Is the 150 dollar bill worth it? Would I need an external oil-cooler for sure since the oil would be hotter than normal without piston squirters?
McMark |
Oct 26 2014, 07:04 PM
911 squirters are often replaced as a peace-of-mind repair. AFAIK, the factory installed 911 squirters are pressed in from the bearing side so removal is just a matter or tapping them back out. The quick retrofit version is to dril from the case register, tap them in and peen them over. But you should be able to tap them out with a rod inserted from the bearing side of the hole.
I'll be doing it the factory way which leaves a little seat material to keep the squirters from popping out. |
wndsnd |
Oct 26 2014, 07:21 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
911 squirters are often replaced as a peace-of-mind repair. AFAIK, the factory installed 911 squirters are pressed in from the bearing side so removal is just a matter or tapping them back out. The quick retrofit version is to dril from the case register, tap them in and peen them over. But you should be able to tap them out with a rod inserted from the bearing side of the hole. I'll be doing it the factory way which leaves a little seat material to keep the squirters from popping out. Not sure about this Mark, from the bearing side these are probably over 2" down their bore. I would say the factory pressed in from the cylinder side and gave them a peen for good measure. John |
Lo-Fi Version | Time is now: 18th May 2024 - 10:05 PM |
