spring rates for rough tracks, opinions and advice sought |
ThePaintedMan |
Nov 30 2013, 09:20 AM
The cool thing is that SVRA's rules seem to mirror the SCCA E-prod and F-prod /4 rules fairly well. So in theory you could build a car for SVRA and have fun and occasionally do some SCCA events, where you may or may not be competetive. If you want to see what a /4 is capable of in it's best prepared SCCA form, check out Racer Chris' (TangerineRacing.com) car. He has one of the most competitive /4s out there and is able to keep up with most Miatas. But he's put a ton of hard work into that car to do so and he's a pretty durn good driver too. (IMG:style_emoticons/default/beerchug.gif)
brant |
Nov 30 2013, 09:46 AM
the 4's are actually better track cars up to a displacement point of around 2.4
if you want more displacement than the path is usually a 6 but head to head a small 4 can be faster than a small 6 now the classes are a completely different story... and those 2 cars don't go head to head in their respective classes. but back to the point the 4's aren't really disadvantaged the vintage rules get specific usually about the technology of the day so for example most clubs won't allow crankfire or Mega squirt because neither were invented in 1972 the 6 cylinders are locked into a 1972 rules base so they are usually 2.0 motors with locked in technology. they are about 50% conversion cars. I'm not sure if SVRA has a cut off year historically most vintage clubs used a 1972 cut off (some are going forward with 1981 these days) factory built 914's only had a 2.0/6 or a 1.7/4 available in 1972 so for a club with that cut off you have those 2 options to choose from. a lot of guys used to get pissed when their 2.0/4 wasn't allowed into a club... the E production ranks for the 1.7 are actually probably a better set of competition than a 2.0/4 would face in 1973.... although some vintage clubs have small enough attendance that they might run those classes in the same run group. (the 2.0 will probably run D production, or D production-1981) depending upon how many new cars are in your club, 1981 ranks can be tough competition... I'm sure chris foley could weigh in on that discussion. basically newer cars with newer technology are always getting faster and faster. so for example the technology in a 1983 944 will be a superior design to a 1973 914... the same adage applies to other cars... so a 1978 or 1981 sports car with the same weight and balance and tune could be faster in the 1981 ranks. luckily there are not many 1981 cars in most vintage racing clubs so the 914 is still pretty competitive in D production ultimately... the most competitive car is going to be built for just one sanctioning body... thus my recommendation that if you are going into svra really build to their rules and you'll have a more competitive car when you get there.... you may give up something in nasa, but you won't have the frustration of having to re-do or undo any of your hard work and money reading the rule book first is the most important step to building a competitive car. |
Seabird |
Nov 30 2013, 04:24 PM
Member Group: Members Posts: 165 Joined: 21-November 13 From: United States Member No.: 16,683 Region Association: South East States |
I am glad to hear they are competative. SVRA group 3 or 8 C and D production allows for the 2L motors with limited modifications. That's probably what I'll build too and run it in NASA as such. That way I dont have to rework it as you say Brant and I will be comfortable with it when I do go w2w.
Looks like there are already a number of things that need to be rolled back on my particular car (IMG:style_emoticons/default/rolleyes.gif) :shrug: Will be fun to build and race!! Miguel |
Seabird |
Apr 3 2014, 03:47 PM
I just ran the first track weekend in the car discussed above and thought it would be appropriate to follow up and give a report regarding the spring rate.
In the end I went with Chuck's (Elephant Racing) recommendation and installed the 23mm/250lbin combination. Although it was a slow test and tune weekend for me and the 914, the suspension was not too harsh at all. I was able to carry at least as much speed through turn 1 as I am used too with the much softer set up e30. (Turn 1 has one of the notorious bumps between apex and track out.) Turn 17 I took slow on entry but was powering out through the big bump at its apex and the car did not get unsettled. Once I started to get the tire pressure dialed in the car felt great on the track. Miguel |
Lo-Fi Version | Time is now: 15th May 2024 - 01:38 PM |
