> Head Temperature top five, *** Give me the top five reasons head temps run high *****
wndsnd
post Nov 28 2013, 04:41 PM
You wanted a horse, but got a goat. Nobody wants a goat....
Oil temp is cool, heads are running hot.
What are the top five .....
brant
post Nov 28 2013, 04:45 PM
Timing
AF ratio
wndsnd
post Nov 28 2013, 04:58 PM
QUOTE(brant @ Nov 28 2013, 05:45 PM) *
Timing
AF ratio
1. Too advanced, or too retarded? I would guess retarded.
2. Too lean? Idle fuel adjusts are two turns out. That should be plenty unless jetting is wrong.
brant
post Nov 28 2013, 05:05 PM
Advanced.
And idle screws adjust idle.
Jets take over under load which is where heat is created.
Also check for blockage in your cooling fan
dfelz
post Nov 28 2013, 05:31 PM
beach bum
QUOTE(brant @ Nov 28 2013, 03:05 PM) *
Advanced.
I have been told too retarded will send more heat to the heads. I would imagine both sides of the spectrum would result in hotter heads.
McMark
post Nov 28 2013, 05:33 PM
914 Freak!
How hot?
Mark Henry
post Nov 28 2013, 05:34 PM
that's what I do!
mice
ConeDodger
post Nov 28 2013, 05:41 PM
Apex killer!
Even in a perfect tune, head temps go up when you are driving uphill or under a sustained load.
wndsnd
post Nov 28 2013, 06:21 PM
QUOTE(McMark @ Nov 28 2013, 06:33 PM) *
How hot?
You don't want to know. According to Raby the engine should have self destructed by now.
wndsnd
post Nov 28 2013, 06:22 PM
QUOTE(Mark Henry @ Nov 28 2013, 06:34 PM) *
mice
Got all the mice.
wndsnd
post Nov 28 2013, 06:29 PM
Just rejetted the mains, and got the temps down substantially. I am working close to Erics calculations now.
But now It bogs down, so I think I may have overdone it.
Also I adjusted the Idle mixture screws a bit richer. (Not the idle speed screws).
I also have a AF guage, but not sure what I am reading, or where it should be. It fluctuates all over from 9.5 to 18.
Getting head temps of 350 - 375. Was over 450 (IMG:style_emoticons/default/icon8.gif)
This is the dANNY engine, so if it blows, it blows. I just need to get it to Tangerine tomorrow and at2 1/2 hours of freeway speeds, I needed to get the temps down, or I would be calling AAA.
I might have to call them anyway.
wndsnd
post Nov 28 2013, 06:30 PM
QUOTE(ConeDodger @ Nov 28 2013, 06:41 PM) *
Not this high!
McMark
post Nov 28 2013, 06:38 PM
914 Freak!
You really shouldn't see anything over 16. 18 is too lean.
You really shouldn't see anything under 12. 9.5 is too rich.
I bet your carbs are out of sync as well.
post Nov 28 2013, 06:42 PM
Did you verify the temp reading.
wndsnd
post Nov 28 2013, 06:43 PM
QUOTE(McMark @ Nov 28 2013, 07:38 PM) *
You can bet on it.
Mark, you are getting my next basket case. I just bought Randy's engine.
wndsnd
post Nov 28 2013, 06:45 PM
QUOTE(76-914 @ Nov 28 2013, 07:42 PM) *
No,
Wish I had an infrared, but the temps are down now. Probably too rich, it is really bogging.
PanelBilly
post Nov 28 2013, 07:26 PM
Harbor Freight has the infrared guns on sale tomorrow
wndsnd
post Nov 28 2013, 07:33 PM
Probably wouldn't help because head temps change so quickly. And when they are loaded you are moving
Kirmizi
post Nov 28 2013, 07:45 PM
Is the thermostat installed and what is the position of your cooling flaps?
914itis
post Nov 28 2013, 07:58 PM
Slight hijack.
Can someone recommend and air fuel gauges for out cars ?
- Lo-Fi Version Time is now: 30th July 2025 - 10:55 PM
