Homemade solid tranny mount..., Had some time to kill.... |
Mike D. |
May 26 2003, 03:30 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,444 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
What do you think of these? I made them from a big hunk of billit aluminum. Center hole is same thickness as a stock tranny mount. Anybody want to take bets on dragging the transmission on the ground? Just kidding, I'm not sure if I trust myself. I guess I could install them then drive around a bit and see if anything is cracking...
-Mike D. Attached image(s) |
Mike D. |
May 26 2003, 03:31 PM
no. 2
Mueller |
May 26 2003, 04:05 PM
They look similar to the units HPH sells, nothing fancy, but they work (IMG:style_emoticons/default/wink.gif)
Ideally, you'd want to have a radius in the corners, less likely to crack, but I don't think you'll ever have that problem with those !!!!! Good job (IMG:style_emoticons/default/mueba.gif) |
LvSteveH |
May 26 2003, 04:24 PM
I put the Poor in Porsche Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 |
Aaron Cox |
May 26 2003, 04:37 PM
looks good! how much did the materials cost? (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/mueba.gif)
Mike D. |
May 26 2003, 07:22 PM
Thanks for the feed back. guess I'm on the right track.
BTW, materials cost nothing, It was scrap billit from where a friend works. -Mike D. |
Mueller |
May 26 2003, 08:10 PM
You can buy scrap from recyclers for a few bucks per pound.
eBay has some good deals on scrap 6061 aluminum as well. I'd say those are less than 5 bucks each in material. |
914Timo |
May 27 2003, 12:53 AM
******* Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe |
QUOTE I guess I could install them then drive around a bit and see if anything is cracking... Cracking ??? Dont worry. They looks very strong and nice. Do you have Bidgeport or something like that in your home garage or do you work somewhere where you can use one ?? |
Lo-Fi Version | Time is now: 28th March 2024 - 10:59 AM |
