914 Fuel Pump fuse on relay board blows |
Sea Dragon 914 |
Nov 29 2013, 06:53 PM
Member Group: Members Posts: 114 Joined: 26-February 03 Member No.: 358 Region Association: Northern California |
Does anyone know what are common causes of blowing the fuse on the engine relay board for the fuel pump and how to diagnose it? Would a bad fuel pump cause this?
Thanks, |
euro911 |
Dec 1 2013, 12:48 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,849 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
The low-rating fuse is the probable cause, but check the path for corroded connections as well. Corrosion on terminals will cause a higher current draw in a circuit.
screenguy914 |
Apr 2 2015, 01:29 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
The low-rating fuse is the probable cause, but check the path for corroded connections as well. Corrosion on terminals will cause a higher current draw in a circuit. To be most correct, if voltage is constant, additional circuit resistance decreases, not increases current flow. Same with faulty ground connections. Except for a partial or complete short to ground (via circuit path or a malfunction in the load itself, bulb, motor, heating element, etc.), circuit current is a result of the total current requirements of the load(s) in the circuit and how the circuit path is wired. However, if a circuit connection point, e.g. splice, connector, etc. has excessive resistance due to corrosion or bad contact, that will 1. reduce voltage and thus current available to operate the load and 2. Create resistance and thus heat at that location. If the loads normally have high current needs (e.g. motors, heating elements, etc.), heat will be created at the point of excessive resistance. I suggest isolating the branch circuit(s) by disconnecting the source wires for each of the loads until the offending load is identified. Oops. Looks like you found the source of the excessive current draw. Congrats on your diagnosis and discovery and suggestions from others. Sherwood |
Lo-Fi Version | Time is now: 18th May 2024 - 11:53 AM |
