vacuum advance cannister wanted for '73 914 1.7L, Bosch Distributor # 231 174 007 |
fullerton914 |
Nov 30 2013, 06:10 PM
Newbie Group: Members Posts: 3 Joined: 29-August 13 From: fullerton, ca Member No.: 16,323 Region Association: Southern California |
my vacuum advance does not hold a vacuum... Having a hard time finding a replacement part
I have a 1973 914 1.7L with the D-Jet fuel Injection system Bosch Distributor # 0231 174 007 pull arm # 917 on vacuum canister Can anyone help? Thanks in Advance |
bdstone914 |
Nov 30 2013, 07:15 PM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
my vacuum advance does not hold a vacuum... Having a hard time finding a replacement part I have a 1973 914 1.7L with the D-Jet fuel Injection system Bosch Distributor # 0231 174 007 pull arm # 917 on vacuum canister Can anyone help? Thanks in Advance I have a bunch of distributors and can check for a good vacuum pot. May not have an exact match but the amount of advance does not vary that much. Bruce |
euro911 |
Nov 30 2013, 07:22 PM
Where did you get that part # from?
Distributors for 1.7L should be 022905205 'x' If your dizzy is: #022905205A, the vacuum unit is #022905271A (two port) If your dizzy is: #022905205H, the vacuum unit is #022905271B (single port) If your dizzy is: #022905205P, the vacuum unit is #022905271C (two port) |
bdstone914 |
Nov 30 2013, 08:21 PM
[quote
[/quote] Got a picture to show if it is a single or dual port? |
euro911 |
Nov 30 2013, 09:11 PM
0231 174 007 comes back as an ignition coil (IMG:style_emoticons/default/confused24.gif)
With a 0231 prefix, I wonder if it's a bus motor, or dizzy? (IMG:style_emoticons/default/popcorn[1].gif) |
fullerton914 |
Nov 30 2013, 10:42 PM
euro911 |
Nov 30 2013, 11:37 PM
According to AA, 'Q' has been discontinued and the replacement is #022905205P
The only other info I found on the 'Q' dizzy was all in Russian. According to the 914 PET catalog, the correct vacuum unit is #022905271C (two port) Do you have an advance and a retard hose on your car? |
fullerton914 |
Dec 1 2013, 01:49 PM
According to AA, 'Q' has been discontinued and the replacement is #022905205P The only other info I found on the 'Q' dizzy was all in Russian. According to the 914 PET catalog, the correct vacuum unit is #022905271C (two port) Do you have an advance and a retard hose on your car? thanks for the info .. I have both -- advance and retard hoses no sure what "dizzy" means? |
euro911 |
Dec 1 2013, 02:19 PM
Distributor
reharvey |
Dec 1 2013, 03:20 PM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
http://www.thesamba.com/vw/classifieds/detail.php?id=1466014
Nothing beats new. I've used these without a problem. Ray |
bdstone914 |
Dec 1 2013, 04:59 PM
http://www.thesamba.com/vw/classifieds/detail.php?id=1466014 Nothing beats new. I've used these without a problem. Ray Did you see the seller in in Cyprus? Fair price on a nos part. |
reharvey |
Dec 2 2013, 11:59 AM
http://www.thesamba.com/vw/classifieds/detail.php?id=1466014 Nothing beats new. I've used these without a problem. Ray Did you see the seller in in Cyprus? Fair price on a nos part. It takes several weeks to arrive from Cyprus. Same guy has been selling these for years. Must have a pile of NOS parts. |
bdstone914 |
Dec 2 2013, 09:59 PM
Found one PM sent
Lo-Fi Version | Time is now: 15th May 2024 - 02:46 AM |
