Piston Orientation Question, Piston Orientation |
Highland |
Dec 4 2013, 09:36 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
I'm installing (reusing) stock Mahle dished 94mm pistons on a stock 2.0 engine and don't see any arrows on the piston crowns to point to the flywheel. I tried measuring the wrist pin offset with calipers to determine an offset and they measure the same on both sides.
I believe my machinest told me to have the block (circled in the picture) on the bottom of the piston toward the flywheel. Is that correct? If not, how do I determine the correct direction of installation. |
Cap'n Krusty |
Dec 4 2013, 10:28 PM
If it's a Mahle piston, there's a mark. Might not be an arrow, but it was marked when it left the factory.
The Cap'n |
Highland |
Dec 4 2013, 11:23 PM
McMark |
Dec 4 2013, 11:54 PM
The box with a squiggley line is supposed to represent a crank and flywheel. The box goes toward the flywheel.
jcd914 |
Dec 5 2013, 12:05 AM
Highland |
Dec 5 2013, 10:13 AM
Does anyone know what the markings on the other side are?
I know the 93... is piston diameter, but what are the rest? |
Lo-Fi Version | Time is now: 15th May 2024 - 01:10 PM |
