Water Cooled Question, Fan sequencing / works great! |
76-914 |
Dec 6 2013, 11:18 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
For my Suby 6 conversion I've installed a twin fan system (from a Dodge) on my radiator. One is single speed (3 wire) and the other is 2 speed (4 wire). Which one of these 2 fans comes on first? Do they both run at times? Will I use the 2nd speed of the 2 speed motor?
mikesmith |
Dec 6 2013, 02:40 PM
Member Group: Members Posts: 202 Joined: 5-September 13 From: SF Member No.: 16,354 Region Association: Northern California |
Based on a quick Google search, it looks like there are two fan control outputs from the Subaru ECU. One is marked "Only for A/C vehicles", so it's quite likely that it won't be switched unless the ECU thinks that the A/C is on.
To start with, I'd wire both fans to a suitably beefy relay and run both at full speed when the ECU asks. You could try to finesse it later (e.g. using a SPAL PWM controller with the ECU fan wire connected to the A/C input on the SPAL controller). |
Lo-Fi Version | Time is now: 19th May 2024 - 04:20 AM |
