Water Cooled Question, Fan sequencing / works great! |
76-914 |
Dec 6 2013, 11:18 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
For my Suby 6 conversion I've installed a twin fan system (from a Dodge) on my radiator. One is single speed (3 wire) and the other is 2 speed (4 wire). Which one of these 2 fans comes on first? Do they both run at times? Will I use the 2nd speed of the 2 speed motor?
BIGKAT_83 |
Dec 6 2013, 04:58 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
I would turn the two speed on first at low speed and then when the temp increased switch it to high speed with the second fan.
On my car I turn on both fans at half speed at 190 degrees and if the temp gets to 200 degrees both fans go to full speed. This is easy to do using 3 relays. Slow speed is the fans wired in series and then put them in parallel for full speed. |
mgp4591 |
Dec 6 2013, 06:28 PM
914 Guru Group: Members Posts: 5,374 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
I would turn the two speed on first at low speed and then when the temp increased switch it to high speed with the second fan. On my car I turn on both fans at half speed at 190 degrees and if the temp gets to 200 degrees both fans go to full speed. This is easy to do using 3 relays. Slow speed is the fans wired in series and then put them in parallel for full speed. Sorry to temporarily hijack this thread, but BigKat- do you have a build thread for your 3.3 build? I haven't seen it and I'm doing the same, just planning stage now but I've got my donor and other pieces. I like your results! |
Lo-Fi Version | Time is now: 19th May 2024 - 05:14 AM |
