Water Cooled Question, Fan sequencing / works great! |
76-914 |
Dec 6 2013, 11:18 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
For my Suby 6 conversion I've installed a twin fan system (from a Dodge) on my radiator. One is single speed (3 wire) and the other is 2 speed (4 wire). Which one of these 2 fans comes on first? Do they both run at times? Will I use the 2nd speed of the 2 speed motor?
BIGKAT_83 |
Dec 6 2013, 04:58 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
I would turn the two speed on first at low speed and then when the temp increased switch it to high speed with the second fan.
On my car I turn on both fans at half speed at 190 degrees and if the temp gets to 200 degrees both fans go to full speed. This is easy to do using 3 relays. Slow speed is the fans wired in series and then put them in parallel for full speed. |
76-914 |
Dec 7 2013, 08:41 PM
I would turn the two speed on first at low speed and then when the temp increased switch it to high speed with the second fan. On my car I turn on both fans at half speed at 190 degrees and if the temp gets to 200 degrees both fans go to full speed. This is easy to do using 3 relays. Slow speed is the fans wired in series and then put them in parallel for full speed. Bob, a million thank you's. Clue me in. I'm lost on those pin numbers. And, I don't know what I've got now; single or dual speed? I cut the harness' from one another because the plug wasn't something I could adapt to. Each fan has 1G, 1B & 1Y wire + one smaller blue wire that went between two plugs. I'm pretty sure it was probably wired so that it could have a high and low speed but I butchered that when I cut that harness apart. Black is ground, but when pos is applied to the Y or G wire, the fan will run. Doesn't matter which one, same speed (IMG:style_emoticons/default/WTF.gif) Nor is it polarity sensitive. Cross + & - and fans still spin the correct way. So it appears that I have two single speed fans, now. They do pull well though. (IMG:style_emoticons/default/smile.gif) Thanks Kent |
Lo-Fi Version | Time is now: 28th May 2024 - 08:15 AM |
