Water Cooled Question, Fan sequencing / works great! |
76-914 |
Dec 6 2013, 11:18 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
For my Suby 6 conversion I've installed a twin fan system (from a Dodge) on my radiator. One is single speed (3 wire) and the other is 2 speed (4 wire). Which one of these 2 fans comes on first? Do they both run at times? Will I use the 2nd speed of the 2 speed motor?
76-914 |
Dec 8 2013, 08:41 PM
Help (IMG:style_emoticons/default/blink.gif) I'm trying to figure this schematic out. I see how low works. Relay #1 throws voltage to Fan #2 then back to relay#3 out pin #87a to Fan #1 and on to ground to power both fans on low. Right so far?? High is where I get confused. When pin33 (or Hi Speed) is grounded then relay #2 sends voltage to Fan #1 as well as 87a on relay #3 where it stops and does nothing because relay #3 is now energized breaking contact between 87a & 30. I'm assuming that pin #42 & #33 are not grounded simultaneously . What am I missing? I don't see Fan #2 getting voltage when hi circuit is energized??? (IMG:style_emoticons/default/WTF.gif) am I missing? (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
Lo-Fi Version | Time is now: 19th May 2024 - 05:25 AM |
