Water Cooled Question, Fan sequencing / works great! |
76-914 |
Dec 6 2013, 11:18 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
For my Suby 6 conversion I've installed a twin fan system (from a Dodge) on my radiator. One is single speed (3 wire) and the other is 2 speed (4 wire). Which one of these 2 fans comes on first? Do they both run at times? Will I use the 2nd speed of the 2 speed motor?
BIGKAT_83 |
Dec 6 2013, 04:58 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
I would turn the two speed on first at low speed and then when the temp increased switch it to high speed with the second fan.
On my car I turn on both fans at half speed at 190 degrees and if the temp gets to 200 degrees both fans go to full speed. This is easy to do using 3 relays. Slow speed is the fans wired in series and then put them in parallel for full speed. |
andys |
Dec 9 2013, 01:21 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
I would turn the two speed on first at low speed and then when the temp increased switch it to high speed with the second fan. On my car I turn on both fans at half speed at 190 degrees and if the temp gets to 200 degrees both fans go to full speed. This is easy to do using 3 relays. Slow speed is the fans wired in series and then put them in parallel for full speed. Bob, I've got three different schematics of this setup, but this is the best I've seen. Yeah, I love the low/high speed function, but oddly enough, it stopped working. My manual fan low/high over ride switches work, so the PCM signal is somehow not getting sent. Time to do some troubleshooting! I'm thinking GM coolant temp sensor failure? I'd like to test it; would you happen to know the resistance values to look for? (slight hijack) Thanks, Andys |
BIGKAT_83 |
Dec 9 2013, 01:45 PM
I would turn the two speed on first at low speed and then when the temp increased switch it to high speed with the second fan. On my car I turn on both fans at half speed at 190 degrees and if the temp gets to 200 degrees both fans go to full speed. This is easy to do using 3 relays. Slow speed is the fans wired in series and then put them in parallel for full speed. Bob, I've got three different schematics of this setup, but this is the best I've seen. Yeah, I love the low/high speed function, but oddly enough, it stopped working. My manual fan low/high over ride switches work, so the PCM signal is somehow not getting sent. Time to do some troubleshooting! I'm thinking GM coolant temp sensor failure? I'd like to test it; would you happen to know the resistance values to look for? (slight hijack) Thanks, Andys The GM LS1 sensor (thermistor) is 29k ohms at -20 degress C and 180 ohms at 100 degress C. |
Lo-Fi Version | Time is now: 19th May 2024 - 05:28 AM |
