Starting rust repair |
last337 |
May 5 2014, 08:43 AM
Member Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None |
Rust repair is beginning again. I have been practicing my MIG welding and am feeling more comfortable moving forward now.
I realized that I didnt have enough measurement prior to taking doors off and making first couple of cuts so I put the doors back just to make sure nothing has moved yet with the few cuts I made. Good news is that the gaps all look good still so I take a number of measurements and then put my braces back in place. Time to start cutting again! I was wondering what type/gauge steel you guys are using for fabbing up small pieces of the frame in places where I wouldnt want to buy the whole stamped out piece from restoration design? I will most likely have to buy the inner wheelhouse, inner rocker panel kit, and the rear floor pan but there are spots where I just need to fabricate small pieces to connect everything together. I will update more pics as a starting point this week. |
saigon71 |
May 5 2014, 07:44 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Rust repair is beginning again. I have been practicing my MIG welding and am feeling more comfortable moving forward now. I realized that I didnt have enough measurement prior to taking doors off and making first couple of cuts so I put the doors back just to make sure nothing has moved yet with the few cuts I made. Good news is that the gaps all look good still so I take a number of measurements and then put my braces back in place. Time to start cutting again! I was wondering what type/gauge steel you guys are using for fabbing up small pieces of the frame in places where I wouldnt want to buy the whole stamped out piece from restoration design? I will most likely have to buy the inner wheelhouse, inner rocker panel kit, and the rear floor pan but there are spots where I just need to fabricate small pieces to connect everything together. I will update more pics as a starting point this week. I used 18GA sheet metal for patching the longs. Good luck with your project and keep us posted. |
Lo-Fi Version | Time is now: 5th June 2024 - 05:59 PM |
